I have burned SVCD's to cdr to watch on my standalone DVD player. In order to watch them I switch the header to standard VCD with tmpgenc. The discs work great.
I want to trade them online as regular SVCD mpgs. So i'm reversing the process. I'm extracting the dat-> mpg with VCD gear 2.0. Then taking that mpg and converting to a regular SVCD by switching the header back to MPG2 header.
The extraction seems to work just fine and the mpg quality playback is fine. But I am having some trouble with the header switch. Sometimes it will mulitplex only a portion of the full mpg. I'll retry to run and get the same thing only a portion of the mpg. Then I'll start from scratch and re-extract the mpg. Again everthing seems ok. Then I go to switch the header, same thing it only will do a portion of the mpg, but this time either more or less than before.
Any suggestions to help me out!
thanks
steve
Results 1 to 1 of 1
Problem with ProjectX - extraction of subtitles from TS with timing errors
By anthara in forum DVB / IPTVReplies: 1Last Post: 23rd Jan 2010, 08:26 -
VOB2MPG Chapter Extraction Problem
By murray666 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Oct 2009, 03:14 -
Strange problem: FAVC extraction always freezes
By Bix in forum ComputerReplies: 0Last Post: 16th Jan 2009, 12:49 -
Stolen Gear
By newsphotog in forum Off topicReplies: 7Last Post: 5th May 2008, 08:42 -
Gear Head DVD+R?
By bevills1 in forum MediaReplies: 1Last Post: 8th Jul 2007, 12:56
