only 213MB??
The .m2v file that CCE created last nite was 2.9Gb (which turned out to be a mess anyway-->jerky, jumpy and skipping..)
make sure that the field order is correct..you can get a lot of the option if you look at the vob files under birate viewer..
just my .02 cents -
Are you sure the encode finished? In multipass vbr each pass is an entirely separate encode. If it crashes %1 into the 6th pass your still only going to wind up with %1 of your encoded movie, even though it has encoded the entire movie 5 times already.
If you want more info regarding what is happening during encoding then set CCE to create a log file. This way you can find out why it might have crashed. -
OK-- will try.. thanks. Oh, one thing... how the heck do you make a CCE log file...? '-)
On the main screen go to, options/outputs and check "output logfile" and set a destination.
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Installing Problems, No file created
By jburkhardt in forum ffmpegX general discussionReplies: 8Last Post: 1st Nov 2008, 22:56 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
