Results 1 to 23 of 23
  1. antone know how i can get the audio off a mov file?want to make it a mps or wav file
  2. Member twodogs's Avatar
    Dec 2002
    Australia
    perhaps TMPGEnc with QTReader, or perhaps Total Recorder...
    "speed's just a question of money. How fast can you go?" - Mad Max, 1979
  3. i tried total recorder but when i play any thing with quicktime and use total recorder the audio gets really messed up. and i also tried the qtreader with tmpgenc. i was able to convert it but there is no audio. do you know why?
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can drop it into soundforge or vegas video (as long as you have installed the qt player) and save it out as whatever ...
    i think you can also do this in QT pro
  5. whats soundforge or vegas video?
  6. there is no way to do anything with QT Pro. i have it and there is no way to make a mp3 or wav file using that. what did you mean install qtreader? its just a file that you paste in a folder. there isnt anything to install
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    i just tried QT and it saved out a wav file with no problems .. use "export" and select wav or whatever .. works fine
    by player i mean just install QT free player from apple ..
  8. i tried export and it doesnt work. it only let me save as mov file. and if i try to change it to wav by just typing wav it doesnt make it a real wav file. i tried tmpgenc and that works but just for teh video not the audio. there is no audio at all
  9. i even got vagas video and it wouldnt even open a mov file, what a piece of crap
  10. Member Cornucopia's Avatar
    To check, I just did an export with QT pro player, just fine. Let's break this down to make sure it'll work.
    1. Are you sure you've got QT pro? If you do, it'll have "SAVE" and "EXPORT" as available options in the file menu. If they aren't there, you don't have QT pro and you can't do much of anything except spend the $29 and upgrade to QT pro.
    2. If this is something downloaded, it could have been compressed with something that doesn't allow exporting/saving, such as MP4/AAC (set during encode) or Mpeg Audio (QT doesn't have tools to demux and decode this).
    3. Also, if this is something downloaded, it could be just a reference movie/redirector. How big is the file? If it's less than a couple of MB, it probably wouldn't be the true movie. So open it up with a text editor, read where the actual source file really resides, and download it directly--by pasting it into your browser.
    4. You do have audio in your movie, right? (Sorry, had to ask)
    5. By now, you should have something exportable. Just do this:
    [ File | Export | Export: Sound to Wave ], name your file, check your options and [ Save ].
    HTH,
  11. Cornucopia how did you get quicktime pro? i had it then uninstalled it because i thought there was something wrong with it. now when i go to the web site it does as me for the code when i download it. any ideas why or where i can get the pro version?
  12. Member twodogs's Avatar
    Dec 2002
    Australia
    Another question:
    Is the MOV from a Digital Camera? I had prob with audio in this instance (from Kodak DC) due to protected/encryted MOV file. But, as mentioned, Total Recorder worked fine for me.
    What is your source?
    Maybe try same techniques described above on a movie trailer or some othe MOV file to see if it is just your MOV that is the prob.
  13. i think it will work if i get quicktime pro i just need to know how to get it. i have the code
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    i just tried again on another mov file -- works every time ..
    export -> sound to wav -> options (set sample rate etc.) -> save
    i have QT 6 pro
  15. Член BJ_M's Avatar
    Jul 2002
    Canada
    i also use vegas all the time for QT files ... works very well , many use it for the same thing ...
  16. Член BJ_M's Avatar
    Jul 2002
    Canada
    just install QT from apple and go to your control panel and open QT settings and pick registration from the drop down list .. and enter your registration info ..
  17. tried it, it still thinks its just qt 6 not qt 6 pro. i checked in the about tab and it says its qt 6
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    doesnt say reg info there -- only in the drop down reg box in your control panel qt settings .. of course if your are using a "bad" reg info -- it prob is blacklisted or something ..
  19. so in your about box it doesnt say its qt 6 pro? i put in crap for the code
  20. Член BJ_M's Avatar
    Jul 2002
    Canada
    no -- doesnt say anything about qt 6 pro in about box -- and you do need a valid code or it will not work .
  21. it finally worked. i think that the code i had last time was probably something a lot of people used so i just hit a bunch of random keys and i was able to save as a wav. thanks a lot for your help, really appreciate it!
  22. Member
    Vancouver, Canada
    This is the situation that I have. Is there a workaround this. I can never get Total Recorder to sync up right. Is there not a program out there that can just rip the mp4 audio?
  23. Member Cornucopia's Avatar
    There may be something to rip this, but if Total Recorder doesn't work, I wouldn't waste too much time trying to figure out a conversion path.
    I would just resort to the Low-tech way of taking the output of the sound card and capping it with another computer, or even looping back into the sound card. You do have to have a full duplex sound card to do this, but then 90% of new cards are.
    If you do want to stay digital, maybe something on the Rarewares site could help you.
    HTH,
