Hi, I've got a nice collection of coasters now and could really use some help making backups of my DVD movies.. I've tried numerous guides, checked out most if not all of the forum topics but I just seem to get a nice round tabletop protectors for hot beverages.. Here's what I do...
1. Use Smart Ripper to extract the .vob files to hard drive
2. Use ifo edit to create .ifo .bup etc etc
3. Use Nero to burn a coaster
I've also tried converting to mpeg2 and using authoring software like MyDVD, Ulead workshop etc and tried several different formats on burning in Nero UDF 1.02 et al, I seem to get the same results each time.. I've tried different media at different speeds and 2 separate DVD burners. I'm currenty using a Pioneer A05, the image before burning can be opened by Power DVD and plays fine, even when it's on disc it works in the PC but on a standalone, not a chance, I either get a No Disc or Disc Error or some other obscure messages.. Have tried all the discs on several standalones (different makes and models) but to no avail. Tried both DVD+R and now using DVD-R on the Pioneer, there must be a foolproof way for me to do it but I haven't found one and it's getting a pretty expensive hobbyIf anyone can help or make suggestions to any settings that I can change please help.. I'm at a loss as to what to do next.. Any help would be appreciated.. thanks
Results 1 to 10 of 10
If you mount the image to view in Powerdvd. Why not just do a DVD copy in Nero from the mounted image to your DVD Burner. That works for me everytime.
NYS,
Could you provide steps, please..? b/c I can't get a darned thing work correctly. Thanks. -
first, my suggestion is to get dvd-rw so it won't be as expensive as you can re-use them and if you were successfull then you can just do a dvd copy on you burning software. Try the turtorial here: http://www.dvd2dvdr.com..it is really good...
just my .02 cents -
Oki so have you get VTS sectors in IFO edit? Otherwise it will not play on any standalone player!
Nero can be the problem so try RecordNow MAX!!! -
when using nero Do not use Nero burning rom use nero express. I have problems when i use nero Burning rom even with UDf 1.02 but if i burn thru nero express It works always with my sony DAV-c770, friends Pioneer RV31, apex, dav-s300 and sons ns300 with DVD-r / +rw/ +R have not tested -RW except with dav-c770
I suspect that Nero is the problem. What I do is:
1) Rip DVD
2) Use IFOEdit to make new VOBs/IFO files
3) Make disc image w/ IMG Tools (can d/load from doom9.org)
4) Burn image with DVD Decryptor
More than likely Nero is burning the discs in UDF 1.05, if you must use Nero see the author links to the left on how to force nero to burn in UDF 1.02
But serious stay the f&ck away from nero for all x(S)VCDs and/or DVD burning. -
Tell us what kind of coasters you have first. If you have coasters because the movie doesn't play after around 60 to 70 minutes do the stuff below for me. If your movie simply gives your machine an error it is probably a burning problem and associated with Nero.
Do me a favor. I am trying to prove something and you may be able to help. Take a your ripped VOBs and put them in DVD2AVI. Click the middle of the movie as the start. Go up and hit Option -> Preview.
Now come back and post what you see in the frame rate and video type boxes. -
i use dvdxcopy, take me 15 to 20 minutes to read, then 20 minutes to burn to dvd+rw per disc, perfect copy,even with all subtibles and channels.
I was just curious what stand alone's you are getting the disc errors on. I have a couple of panasonic's that are real picky. I assume you are doing a stright rip and flip no encoding?
Dd
Strength and Honor(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
HP DVD+R coasters...
By lost123 in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2010, 16:48 -
Total Media Extreme makes coasters when creating DVD-AVCHD
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 29th Mar 2010, 14:53 -
Verbatim Coasters
By hech54 in forum MediaReplies: 6Last Post: 25th Jun 2009, 18:16 -
Roxio 8 misunderestimates DVD capacity? making lotsa coasters...
By ahhaa in forum ComputerReplies: 8Last Post: 7th Sep 2008, 19:57 -
Getting coasters with Nero 7???
By dagerousdave in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 20:12
