I have two quick question.
1) Is there a tutorial or a way to get the original background pics from the dvd menu's to use on the backup dvd?
2) Is there a free software tool that inserts menu's and chapters or am I going to have to invest in Movie Factory?
Thanks.
Ben
Originally Posted by ben4vols
I use Maestro for Authoring and menus. I am not aware of any free programs to do this.
There are several ways to get the menus into .JPG or .BMP files that must be 720 x 480 for Maestro. I use STHSVCD or PowerDVD player.
In the TOOLS section of VCDHELP:
VCD,DivX,AVI,MPEG1 Players
You will find STHSVCD
A VCD, MPEG Player. Supports also SVCD, DVD if you have installed a software DVD Player. Freeware.
http://dvdarea.free.fr/studio/lecteurs/sthsvcd_55.exe
Here is a quick and easy way to capture a video scene as an image using PowerDVD.
http://www.gocyberlink.com/english/products/powerdvd/tips_tricks/screen/screen_tips.jsp -
hear is a great guide and it uses all freeware
http://home.att.net/~adam.poole/Introduction.htm
hope it helps -
i found the link in the forums
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Soo confused
By slaak in forum Newbie / General discussionsReplies: 9Last Post: 10th Aug 2009, 19:44 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 16:42 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 12:42
