How I conver the WMV file to a mpeg to burn vcd?
I use tmpgenc to encode, it just stop and no action?
<font size=-1>[ This Message was edited by: moon on 2001-09-02 09:44:53 ]</font>
I'm using tmpgenc 12a all time.
it encode 10min and stop no work.
I try 4 to 5 time ,still same,is there some way
to do it?
thx -
The problem is the audio stream of newer Windows Media files. Try just encoding the video stream with TMPGEnc - it should work.
To encode an MPG with video and audio, you'll have to extract the audio stream to WAV using Graphedit. I haven't done that in a while, so I can't describe the process, but there are a number of sites on the net that can tell you how to do it.
Older ASF files work fine in TMPGEnc, by the way.
Conver MKV to AVI with same size and quality. How ?
By SB4 in forum Video ConversionReplies: 1Last Post: 7th Aug 2010, 14:49 -
How to conver series discs to seperate episodes
By Raffaz in forum Newbie / General discussionsReplies: 4Last Post: 15th Feb 2009, 06:56 -
Best format to conver to for web?
By silver007 in forum Video ConversionReplies: 6Last Post: 1st Jan 2009, 09:51 -
what is the best program to conver rmvb to mpg2??
By sleung in forum Video ConversionReplies: 4Last Post: 20th Feb 2008, 00:28 -
Problem conver with TMPGEnc Plus-2.54.37.135
By sleung in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 14:53
