I have downloaded several movies from the net in divx/xvid format and they play perfectly on the PC, however when I convert to mpeg1 via tmpgenc the sound goes out of sync sometime during the moving. This only occurs on one or two of the movies but it is really annoying me since the divx plays ok.
I have seen posts regarding cutting the bad frames out, which is very time consuming since virtualdub doesn't find them when you ask it to scan the file. It means I have to scan through the mpeg until I find a point when the audio goes out of sync then home in on the same time in virtuldub.
I can't understand why the divx file is handled ok, can't an encoder automatically remove faulty frames and its associated audio, or even insert still frames in its place.
I have thought about playing the divx out to a tvout port and loop it back into a tv capture card and capture in mpeg(sound could also be looped back in). I can imagine this will work but I will obviously be introducing noise and going through a digital-analog-digital conversion will reduce quality.
Is there no way of short-cutting this and have some software that captures a window or defined area to an mpeg file just like these screen capture utilities you see for giving screen prints. Although not an elegant solution it would certainly make life easier than searching for bad frames, cutting them and trying to encode for another hour or so to see if you fixed it.![]()
p.s tried several dvd authoring tools, mainly sonic mydvd, and everyone seems to transcode the tmpgenc encoded file further. Is there a dvd authoring package that takes in avi/divx/xvid files and transcodes in one step at a reasonable speed?
Results 1 to 1 of 1
Problems converting from mp4 to mpeg1
By chukde in forum ffmpegX general discussionReplies: 2Last Post: 24th Feb 2009, 18:12 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
sudden vdub sync problems when converting hd sources
By uk_dan2k in forum Newbie / General discussionsReplies: 10Last Post: 8th Feb 2008, 16:37 -
converting from mpeg1 to divx
By mlkwestcoast in forum Video ConversionReplies: 3Last Post: 21st Dec 2007, 11:09 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 15:34
