I have been playing with VCD's and I got a DVD burner for my birthday. Panasonic A05. So my question is that I want to convert my home videos to DVD. I have a ATI All-In Wonder Video Card 32 mb. So my questions is how would you capture the videos (resolution) and what DVD authoring programs would you use. Any help would be greatly appericated.
Ulead DVD Workshop can import AVI directly. Learning curve is very small and you can create menus with music. Motions menus without music though. You can also import the trial version for free.
Use Ulead to capture. Get your *.avi - then demux, seperate your video and audio, use TMPGEnc get you bit rates etc. and mpg2 files in order, then use DVD Maestro (for authoring) which will put your audio and video back together and finally use GearPro for burning. I wish I had this info when I got started. I have learned the hard way and spent a lot of $$$ doing it. You will have perfect DVD's and they will play in any set-top.
I actually just use Ulead without usingTMPGEnc. I use to get the fast motion problems in TMPGEnc (DVD ripping ok, but with DV->firewire - I had problems). If you use the raw AVI in Ulead ( skip a step) it will convert to vobs for you. For ripping DVD's use TMPGEnc, if you have raw AVI go directly to Ulead and compile.
I've had problems with the sound, garbled (almost a slow motion for sound). That is why I do it that way.
Blu-Ray Burner Advice Please
By leebo in forum DVD & Blu-ray WritersReplies: 25Last Post: 22nd Sep 2012, 12:49 -
DVD burner advice please! Good current models?
By Bubblevision in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Dec 2011, 08:04 -
Need advice about buying a Dvd-R DL burner
By southrngntlmn1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd Apr 2008, 13:12 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
advice on an SATA dvd burner?
By lumis in forum ComputerReplies: 4Last Post: 19th Jun 2007, 05:09
