  1. i want to make menus. but i want to be able to select the button by using the arrow buttons on the remote instead of the button buttom number. say for example two buttons i want to be able to go from button one to button two by pressing arrow keys not number two on the remote. thanks
    May 2001
    Well, gee, then why don't you map the buttons?
  3. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Same here m8, i also wanna know if it's possible to do it with Maestro like you said.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    yea -- in maestro go and hit "map buttons" auto .. and adjust any that are out of wack for what maestro assigns .. or you can just enter them manual in the button menu ..
    its all clearly laid out in the manual ..
  5. removed - discuss "personal" problems private
  6. Such language
    If you don't happen to have the manaul, here are some guides:
    http://www.dvdwriters.co.uk/articles/DVDMaestroUnleashed.pdf
    http://www.doom9.org/index.html?/mpg/maestro.htm
    Also, I found the Maestro Help file to be quite helpful.
    Actually, you can get some really good help on the yahoo dvdmaestro group. Maybe they can point you to the manual and help Files
    May 2001
    removed - discuss personal problems private
