Alright, here's the scenario.... (and I've tried this with two DVDs)
I've ripped the "TITLE01-ANGLE1.VOB" from each of the DVDs which ends up being about 5GB
I then drop this file into FFMpegX 6.0 and choose SVCD I calculate the bitrate so that the movie will fit on two 80min CDs (about 1800kbps), set it to Dual Threaded CPU, select the right ratio aspect, tell it to split the movie into two chunks and Author as an SVCD as a and pretty much leave the rest alone.
It goes through the whole encoding process that used to work like previous versions of FFMpegX but here's what I get for output files...
Movie_Name-1.mpg (272MB)
Movie_Name-2.mpg (4kb)
Movie_Name.mpg (276.1MB)
Movie_Name.m2v (79.4MB)
Movie_Name.mp2 (192.5MB)
Moive_Name-1_01.img (692kb)
Movie_Name-1_02.img (272MB)
So you might wonder what the problem is?
Well for starters, it only split it into two IMG files for the first CD, when I'm supposed to get 4 (2 per CD).
Secondly the movie is only 272 MB!? No... I assure you it's not It's come up with about 275MB on both the DVDs I've tested. And the final movie file isn't the whole movie, it's sorta "corrupted" part way through watching the file, the video STOPs and the audio keeps going.
Each of the VOB files are about 5GB, and I'm absolutely 100% sure that I'm using the right title file. (Number 1 in this case)
So maybe I'm off the wall or something, but this isn't working like it used to.
But I guess the plus side is that the final file, up until the video cuts off, is in sync?![]()
Flip
[/list]
Just so you can take a look at what the terminal does, heres the output....
Maybe it might explain why it doesn't work...
Last login: Thu Jan 23 09:27:03 on ttyp1
pbpaste | sh
Welcome to Darwin!
[Omega:~] omega% pbpaste | sh
Encoding started on Thu Jan 23 15:43:30 EST 2003
++ WARN: [mpeg2enc] 3:2 movie pulldown with frame rate set to decode rate not display rate
++ WARN: [mpeg2enc] 3:2 Setting frame rate code to display rate = 4 (29.970 fps)
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
++ WARN: [mpeg2enc] Frame height won't split into two equal field pictures...
++ WARN: [mpeg2enc] forcing encoding as progressive video
a52dec-0.7.4 - by Michel Lespinasse <walken@zoy.org> and Aaron Holtzman
No accelerated IMDCT transform found
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 4294967256 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
225316 frames in 3650.57 sec (61.72 fps), 62 last 0.73 sec (84.93 fps)
225364 frames decoded in 3650.92 seconds (61.73 fps)
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.mp2"
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
INFO: [mplex] File /Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Selecting SVCD output profile
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 304
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 1411200 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.mp2)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1674800
INFO: [mplex] Setting best-guess data rate.
INFO: [mplex] Sectors = 78 Video delay = 77929 Audio delay = 77929
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 235520 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 9907
INFO: [mplex] STREAM e0 completed @ 9907.
INFO: [mplex] STREAM c0 completed @ 300484.
INFO: [mplex] Multiplex completion at SCR=649115346.
INFO: [mplex] Video e0: buf= 235520 frame=009907 sector=00024845
INFO: [mplex] Audio c0: buf= 736 frame=300484 sector=00087947
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 7044503 bytes
INFO: [mplex] Sequence headers: 694
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 9908
INFO: [mplex] No. Groups : 694
INFO: [mplex] No. I Frames : 694 avg. size 14136 bytes
INFO: [mplex] No. P Frames : 2652 avg. size 6789 bytes
INFO: [mplex] No. B Frames : 6562 avg. size 4349 bytes
INFO: [mplex] No. D Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 1090800 bits/sec
INFO: [mplex] Peak bit-rate : 1518400 bits/sec
INFO: [mplex] BUFFERING min 42696 Buf max 225911
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 201925920 bytes.
INFO: [mplex] Syncwords : 300485
INFO: [mplex] Frames : 300485 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 67 Buf max 683
INFO: [mplex]
INFO: [mplex] MUX STATUS: no under-runs detected.
Size of Fix: 0x914
now reapplying junk-header ....
Now processing /Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.mpg [1/2] ...
Now processing /Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.mpg [2/2] ... failed, range results in an empty chunk
-------Done--------
(Super) VideoCD xml description created successfully as `/Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.1.xml'
++ WARN: initializing libvcd 0.7.12 [darwin5.2/powerpc]
++ WARN:
++ WARN: this is the UNSTABLE development branch!
++ WARN: use only if you know what you are doing
++ WARN: see http://www.hvrlab.org/~hvr/vcdimager/ for more information
++ WARN:
++ WARN: audio stream #0 has sampling frequency 48000 Hz (should be 44100 Hz)
++ WARN: SVCD/TRACKS.SVD: playing time value (7211 seconds) to great, clipping to 100 minutes
(Super) VideoCD xml description created successfully as `/Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.2.xml'
++ WARN:
++ WARN:
++ WARN: mpeg stream contained no scan information (user) data
++ WARN: mpeg stream shorter than 75 sectors
++ WARN: sequence items should contain a motion video stream!
++ WARN: SVCD/TRACKS.SVCD: No MPEG motion video for track #0?
!ASSERT: file vcd_data_structures.c: line 217 (_vcd_list_begin): assertion failed: (list != NULL)
sh: line 1: 1604 Abort trap /Volumes/ffmpegX0.0.6d/ffmpegX.app//Contents/Resources/vcdxbuild -q --cdrdao-file=/Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet-2 /Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet.2.xml
rm: /Users/omega/Desktop/DVDs/ROMEO_JULIET/Romeo_Juliet-2_02_pregap.img: No such file or directory
Encoding completed on Thu Jan 23 17:07:54 EST 2003
[Omega:~] omega%
Strange BD Rebuilder problem - Output files too small??
By YBS1 in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 19:20 -
ffmpegX 0.0.9 - no sound in the output of a transcode
By mattr in forum ffmpegX general discussionReplies: 2Last Post: 21st Sep 2008, 02:56 -
FFMpegX Output files
By Dearg800 in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2008, 15:50 -
Strange AutoGK output files
By bennyboy371 in forum DVD RippingReplies: 7Last Post: 14th Mar 2008, 08:21 -
Strange Flicker in DVD with ffmpegX encoding
By angeloftheodd in forum ffmpegX general discussionReplies: 3Last Post: 2nd Jul 2007, 21:49
