  1. i use TMPGEnc the file Ext. is mpeg2 (mpg)
    i want the file Ext. will be M2v that way SpruceUp can recognize my AC3 stream and load it as he load the M2v file, i tried to load mpeg2 file but he did not load the AC3 file..
  2. Open TMpegEnc, go to "File/Mpeg Tools/Simple Demultiplex". Load your MPEG movie, specify filenames for the streams and run.
    But I don't think you will be satisfied with the result. If you used TMpegEnc to produce the MPEG, then your audio source was definately NOT AC3. And after de-multiplexing you will have an M2V/MPV and an MP2, which is not AC3, either.
    So, if you don't have an additional AC3 file with the same audio data as in your source, forget about it.
    There are only 10 types of people in the world:
    Those who understand binary
    and those who don't.
  3. Member wulf109's Avatar
    Jul 2002
    Newer versions of TMpeg.2.58 or higher allow you to select video only as an ES video steam and that will encode your avi into an m2v.
