Load/Save is not yet finished, but I prefer to publish VCDEasy 1.1.4 now, without the load/save yet, because a lot of bugs around the Media Player have been fixed, and the Nero ASPI support may help a lot of people having CD writer detection problems.
Better recognition of the Adaptec ASPI version if any
VCDEasy can now use Nero's ASPI layer if there ("WnAspi32.Dll" in the folder of Nero [and also "NeroApix.vxd" in "Windows\System\IOSUBSYS\" on Win9x/Me])
If you know what you are doing... you can force the use of a specific ASPI layer in putting the corresponding "WnAspi32.Dll" file in the CDRDAO folder. Note that an ASPI layer may be more than just one file, so be careful to have all of them installed...
Several bugs/improvements related to the Media Player box (in the chapters page) has been fixed/made. It should be more robust now. In theory, VCDEasy should be able to read what the Windows Media Player 6.4 (located at: "C:\Program Files\Windows Media Player\mplayer2.exe") can read... But, according to some users, it is not always the case... It depends in fact on the codecs (DirectShow filters in fact) your Media Player is using. Also, note that if your Windows Media Player is unable to resize a video under their original size (because of the codecs), then you may have sound but no video in the VCDEasy's Media Player.
A bug fixed in the display when Windows large fonts (yet another one...)
I removed the About, History and Credits pages, and replaced them by dialog windows accessible via the "Help" menu.
The history is now displayed as RTF document.
The version of each language file is now displayed.
Fixed bad display of small icons when the user is not an Administrator on WinNT/2k/XP.
Put "NoAutopaddingWarning=1" in the VCDEasy.ini file to not have the warning for MPEG files which require autopadding
Put "NoBadPacketsWarning=1" in the VCDEasy.ini file to not have the warning for MPEG files which have bad packets
The "Approximate CD size" computation has been (again...) improved.
VCDEasy is now more robust to errors in the language files (VCDEasy 1.1.3 was not usable with the Czech language file)
Bug fix when adding a file with bad "Last Modified" information
Bug fix related to some CD writer speed selections
Russian Translation by Vladislav Kugelevich (Thanks!)
Turkish Translation by Solid Development (Thanks!)
______________________________
http://www.vcdeasy.org/
