allright, just got a audio-cd from friend.. on the cover of the cd it says, "Will not play on PC/MAC", and yes, it doesnt work.. Is there any program or something so i can play the cd on my PC?
TIA
frozenQ
Turn the CD and look on the side with te audio data (not the side with the text description). Do you see a extra ring of data on the outer side ?
than thats the data how tels your computer that it is an non audio disc for computers.
Take a yellow post-it and stick it on the outer ring only, now your CD-rom reader doesn't see the data that tell it that is not for PC and it is playable again. -
You could also try ExactAudioCopy or Plextools (if you have a Plextor drive) to rip the tracks. I've not been without success with these tools (even if I've been forced to give up on the occational track now and then).
/Mats
How to copy protected cd
By nusratjaveid in forum DVD RippingReplies: 14Last Post: 29th Jul 2010, 22:15 -
how to rip an audio off the net, when the audio is blocked/protected?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2008, 10:14 -
does IT convert protected audio files?
By doulos in forum ffmpegX general discussionReplies: 0Last Post: 13th Jul 2007, 04:41 -
Protected AAC
By JaredKnight in forum AudioReplies: 4Last Post: 19th Jun 2007, 10:30
