I capture from vhs video. I'm using a MSI Geforce ti4200 and the video in, not svhs in. I've installed the detonator 41.09 and the WDM drivers 1.08, I had to switch to the WDM1.08 because of Macrovision Problems... huge white stripe..
I tried capturing with vdub, avi_i_o and virtualVCR. Vdub and avi-io always cut of a few lines at the bottom of the screen. So in the captured file I'm missing this part and that's unacceptable. There's no change if I use other formats.
I heard that you can't use WDM drivers in vitualdub and so I switched to virtualVCR. VirtualVCR gave me a really fine picture capturing at 720*576 to DivX 2500Kb/s but the Audio/Video isn't in sync! There aren't many options to configure, so I checked the box "resample Audio/video dynamically".. but this didn't fix the prob.
I'm missing an option "adjust video to audio clock every 500ms".. or something like that in virtualVCR.
PLZ help!! THX
Hi,
I am having the same problem with a MSI GeForce4 Ti4200-VTS8X card. I am capturing with the PAL system from an analog camera. connected to the Video IN.
I have not yet managed to overcome the problem. I am using Pinnacle Studio 8.3 and VirtualDub 1.4.13 (FYI it can capture using WDM drivers).
Did you manage to overcome the problem using the virtualVCR? How did you manage that?
I am using MSI 41.07 drivers and Nvidia WDM 1.22 Capture drivers. (I also tried Nvidia 41.09 and WDM 1.18 with no success
If you can find a solution plz let me know (the same applies to me)
I don't think Vdub can cap in WDM. It can *sometimes* cap using the VFW for WDM wrapper. I said sometimes because it's never worked on my system. The VdubMod can open Mpegs now but I can't seem to get it to open up in TMPGEnc without a crash, so I've had to discard it as well. Too bad as Vdub has the best filters available when capping from VHS tapes...
You are right about Vdub (sometimes I made it capture using VFW).
However, do you have a hint about the capturing problem? -
For me Virtual VCR works fine now.
The problem was the high resolution. Now I'm capturing at 352x288 PAL and no more sync probs..
cya -
I glad that you made it work.
However, my problem is not what capture software to use, but a hardware/driver problem. Whatever, software I use (VirtualVCR, Pinnacle Studio 8.3 etc.), the bottom lines of the captured frames are crambled.
I have nt found a solution yet. -
hi richta, those white bars that u mentioned, what are they. how to get rid of them ?
u mentioned switching to older wdm1.08, did that solve the problem and did that cause any performance degradation ?
i use geforce 3 latest detonator and wdm1.19. i am currently capturing at 760x480@29fps & 6500kbps.
i get the white bars only when i am recording something from VCR, and especially when there are noise bars during playback.
bye.
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 09:30 -
Sony capture probs
By DaveDLF in forum Capturing and VCRReplies: 13Last Post: 23rd Mar 2009, 21:20 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 20:25 -
DVD Shrink Probs..
By Superstar24 in forum Newbie / General discussionsReplies: 33Last Post: 19th May 2008, 16:54
