What codecs do everyone prefer for capturing from Vdub or IUVCR. All i know of is Huffy, any other good ones. I am going to end up putting it on DVD so i want best quality
Huffyuv is the best one, second is PicVideo MJPEG. with manual setting of 4, 4 (1:1:1) at 720 x 576 x 25fps, the datarate is somewhere between 3000-5000 KB/s. With that setting, the quality loss is only noticeable via Photoshop (zoom & gamma tilting).
MainConcept DV codec seems to be an option too. Data rate around 5000 kbps, which is between PicVideo Q19 and Q20.
DV CODEC for VHS Capture?
By enbidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 140Last Post: 24th Feb 2011, 20:11 -
Anybody used FFDshow Mjpeg codec for capture?
By davexnet in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2010, 00:27 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 13:53 -
The Best Capture Codec to reduce artifacts is???
By maxtrack in forum Capturing and VCRReplies: 5Last Post: 27th Jul 2007, 15:47 -
Video Capture Codec
By ThatOtherGuy in forum Capturing and VCRReplies: 17Last Post: 2nd Jul 2007, 02:18
