I have a movie that I downloaded.
When I look at the properties for it, it says it is a video clip.
In the title it has DVDivx.
Audio format is MPEG-3
And video compression says Divx codec.
I assume this is a Divx film that was ripped from a dvd due to the excellent quality of it.
What I am wanting to do is convert it so that I can burn it on DVD-R's and watch it on my dvd players.
I want it to be the best quality possible.
I used VDUB mp3 and it only gave me a 502kb wav file.
I split the file into 2 identical size files.
Just tried reencoding under TMPGEnc, and it didn't give me any sound. I assume this is because the wav file wasn't correct since it is so small. But it looked ok, just no sound.
Any idea what I may have done wrong??? I am pretty sure I followed the King's guide pretty much too the letter on using VDUB and also the guide for converting to dvd with TMPGEnc.
I know my main problem was the audio, but I am wanting to make sure I do the rest of the process correctly.
Thanks for any help and suggestions!!!!!!!!![]()
hey slug guy, i'll show how to have sound in ur movie
first in virtualdub go to file and load up ur avi file and once u have done that go back to the file option and click on save wav. save it to whatever u want to. once u hit save it should start the encoding process which on my old pc takes a few minutes. once its done u should have a 700mb file give or take. now all u have to do is load it up in the audio source in tmpge and u should be fine
happy encoding!!!! -
Thanks, it did work. Encoding right now. Like I figured, I was doing something wrong.
Thanks again 8) -
no problem slug guy, i've been encoding with tmpge for about 2+ years and i pretty much know how to fix some problems :P
have fun!!!!
How to burn 1920x1080 mpg to dvd without loss of quality?
By ABUELLO in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2013, 15:48 -
DVD burn runs too hot, how to slow down reading the source disk
By loninappleton in forum DVD RippingReplies: 6Last Post: 28th Apr 2012, 09:31 -
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
Movie quality is bad after burn to DVD
By ngochan in forum Video ConversionReplies: 4Last Post: 26th Jan 2011, 00:34 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 23:03
