  1. Ok folks, im pulling my hair out here over this. Heres my prob: when playing some movie titles The video and audio get out of sync. Ive tried everything under the sun to correct this and it makes movies unwatchable
    here are my system specs:
    p3 450 mhz
    256 mb 100 mhz sdram
    3dfx voodoo 3 video card 16 mb
    sb awe 32 sound card
    running win xp build 2002
    mediaplayer 7.01
    anyone got some ideas? Hardware or software probs?
    gimme a holler here or via q if ya can help me out!
    12294663
  2. Did you check if the movies play correctly on another PC ? cause sometimes it's not the movie's fault, it's the Playback Codecs which are being used on the PC.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
