Hi there,
I need some helo: I have a xtasy everything card to make captures of Vhs to dvd. I am happy with drop frames though it varies; however, I still drop some. I was wondering if the ADVC 100 from canopus if worth the money and forget about my xtasy card? I really don't know what to do and have not heard of anyone making the comparison between the two
Guillaume
all I can say fabout mine is 0 dropped frames and synched audio.... also you can use it without a computer from DVD 2 VHS... IMHO, well worth it
what about quality? Do you get at least equal quality from original vhs? One of the annoyances of using the xtasy and probably any capture card is all the tweaking and adjusting that you need to make in order for things to go smoothly. I think the canopus is simpler in use for same results...?
Thanks,
Guillaume -
http://www.vcdhelp.com/capturecards.php?CaptureCardRead=Canopus%20ADVC-100&Search=Search
It's the top rated capture card for a very good reason - it's the best. I know, I have one!
Regards,
Rob -
In my opinion the ADVC-100 is the best ! No lost frames and the quality going back to VHS is as good as the video going in. Well worth the price.
PS Stay away from all Dazzle products!! -
if you have a high def tv, encode the dvd in low res dvd in tmpeg, it will look like the original. if you burn in regular 720x dvd mode, the vhs conversion will be pixelated on a high def tv (or ready like my sony 36xbr400) but look fine on regular tv's
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 14:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 08:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
