I need a new dvd drive because my old drive is broken.and don't won't to use my dvd writer for ripping.
So what dvd-drive would you recommend that has a good ripping speed.
Results 1 to 10 of 10
I have a Pioneer DVD-500M (16x DVD, 40x CD.) It works really well. It rips DVD's quite fast and audio cd's in like 3-5mins. I don't know if you can get it anymore though. I have seen some DVD-ROM drives listed as Pioneer 16x DVD-ROM OEM.
Get the Lite-on 16x drive. It's not locked at 2x for CSS discs. I normally rip at 5-8x. Although for series (region 1 DVD-5) I got 11x ave and 15x max in DVD Decryptor
I got the Lite-on 16x dvd rom and it is great. It's quite and able to rip and read any dvd I through in there. I use clad and smartripper.
Price is also good too. You can find it online for about $37 at www.pricewatch.com -
what he said. They can be had for under $50 as well... pcclub had them for $34.99 over xmas.Originally Posted by Vejita-sama
-d -
I heard LiteOn had high ripping speeds, but I don't know if it's a decent device. I mean every device works perfect while it's new, but will it still work after 6 months of ripping?
I have a Toshiba device for 2 years, not the fastest, but it still rips and works properly
I had a lot of reading problems with my previous Pioneer device. Probably specific problem to the device, but still...
MrSnake -
Well I'm after about 9 mines alive an kicking fine. An excellect drive that I have recommended to friends that they themselves have liked.
I have a Plextor LTD-163 and Pioneer DVD-117. Both are EXCELLENT drives for DVD rippin'.
Check out this review on the new MSI StarSpeed 16x DVD-ROM Drive - $45
http://www.vcdhelp.com/forum/viewtopic.php?t=138986 -
Here's another vote for the Lite-On. I've had my 163 for a while and never had a problem with it. Like others have stated, they are readily available and inexpensive too. A great perfomer, even greater value.
Get the liteon 16x drive here
http://www.nexthardwareshop.com/dvdromdrives.html
only $23 plus $11shipping. best price around for retail package. Thats wher i got mine and i love it
Video Card Recommendations needed
By Noahtuck in forum ComputerReplies: 7Last Post: 7th Jul 2010, 12:17 -
Looking for recommendations on USB 2.0 enclosure for 2.5" SATA drive.
By Xylob the Destroyer in forum ComputerReplies: 3Last Post: 14th Jun 2010, 20:40 -
External Hard Drive Recommendations.
By bbanderic in forum ComputerReplies: 4Last Post: 1st Jan 2010, 09:42 -
External Hard Drive recommendations
By mccoady in forum ComputerReplies: 22Last Post: 5th Nov 2009, 07:48 -
HELP needed with the installation of a second Hard Drive!
By gary11364 in forum ComputerReplies: 4Last Post: 10th May 2007, 14:17
