Im trying to extract the audio from a movie but when I open it I get an imporoper VBR audio encoding error. So I checked the file information option and I get this info:
Frame size, fps: 576x304, 23.976 fps
# of frames (time): 153252 (1:46:31)
Decompressor: XviD MPEG-4 Codec
Sampling rate: 48000Hz
Channels: 2 (stereo)
Sample Precision: 0-bit
Compression: Unknown (tag 0055)
I tried to make an AC3 file using VirtualDub which works fine, but when I try and open it in HeadAC3he I get a “could not find AC3 header”
Now I also tried to just encode the file using TMPGEnc without extracting the audio but when I select the Audio file (Video file opens fine) I get an error saying File “D:\signs-xvid.avi” can not open , or unsupported.
Anyone know what I can do to fix these problems?
MikeWeb
http://mikeweb.atnet.ca -
i had the same error repeatedly so i gave up and tried besweet and it worked like a charm do a search for the guide it is very helpfull.
Should I encode it into mp3 or another format?
MikeWeb
Problems importing ac3 in Vegas Pro
By mltwitz in forum AudioReplies: 0Last Post: 12th Jun 2010, 12:55 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 02:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 04:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 17:33 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35
