hi all
when i start up virtualdub 1.4.13 and go to video---->compression it lists all the different compression things i have eg. picvideo,huffyuv etc (about 17 in total)
the problem is when i go to file---->capture avi------>video---->compression it only displays about 4 compression things in there and i don't use any of those 4![]()
any idea why?
thanx
When capturing, VirtualDub filters out any codecs from the selection list that cannot be used with your current capture settings and capture hardware.
Some codecs on your PC are used only for de-coding and can't be used for capture. Others will only work if compatible capture settings are selected.
For example HUFFY will only work if you capture in 24bit RGB or YUY2.
Try changing the settings and note the effect on the codec list. -
Yes, VDub is looking first the colordepth You using during capture.
When you selected YUV for example you can only compress with the codecs thats understands YUV and also VDub displays only these codecs.
BTW use RGB24 for the best quality.
Regards -
thanx guys
that's exactly what the problem was......i didn't have it set to rgb or yuy
different compression virtualdub
By chewie8008 in forum EditingReplies: 14Last Post: 8th Aug 2009, 13:45 -
Virtualdub compression
By quxote in forum Newbie / General discussionsReplies: 25Last Post: 26th Jul 2009, 08:59 -
[?] Audio Sync & Compression Problems. Trying to start a series.
By shibbuh in forum MacReplies: 2Last Post: 26th Nov 2008, 17:26 -
virtualdub compression for dx50?
By majax79 in forum EditingReplies: 4Last Post: 22nd Dec 2007, 22:51 -
Audio compression with VirtualDUb!
By kehn in forum AudioReplies: 5Last Post: 27th Jul 2007, 01:10
