Hi,
Hauppauge Wintv USB Pal B/G.
XP Pro, 256 MB, 4 GB free.
I can capture at 25 fps with iuvcr at 352x288, compresed with divx. Not bad, but zoran web (producer of usbvision, capture chip of the card) expose that can capture VGA format at 15 fps.
No program detect de config. I have to modify the .reg? Some suggestions about program-codec-soft-driver?
Thanks.
Results 1 to 1 of 1
640x480 14,9fps video from mobile to 25/30 fps posible?
By mammo1789 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Mar 2012, 07:06 -
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 19:57 -
Should I use 640x480 or 320x480 with cubic for VHS capture
By groove365 in forum Capturing and VCRReplies: 4Last Post: 1st Sep 2010, 02:23 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59 -
AverTV Studio capture problems at 640x480
By SuperFlyBaconG in forum Capturing and VCRReplies: 1Last Post: 3rd Aug 2007, 06:34
