First attempt kinda yucky
First VCD. Created it with DVD2SVCD and TMPENgc. DVP player recogizes
it but it plays VERY jerky....freezing up on one frame for 5-10 seconds. I'm not sure where to start to troubleshoot it.
Based on the symptom, are there any suggestions?
Tia for any help.
Gary
Ahhhh, I remember my 1st VCD, it was like 3 years ago and I didn't know sh!t from Shinola.
Media may be your problem as some DVD players will only play CD-RW's and not CD-R's, even if they are VCD compliant. Try another format or brand of CD-R or RW.
Ahemmmmm, As to your question, TMPGenc is a very good program for creating MPG1 video files for VCD. There are strict rules for creating a compliant VCD that will play in VCD compliant DVD players. Be sure to use the VCDntsc template for NTSC (U.S.) video format. -
I'm just wondering...you are using DVD2SVCD? I thought you were making a VCD?
Sakuya:
DVD2SVCD has built-in settings make VCDs, CVDs and SVCDs. There is even a DVD setting although I'm not sure if this is truly for DVDs or just DVD resolution.
Backwards running
By Zenner in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:41 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
Help: New to running virtualdubscript
By crouzilles in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2009, 14:00 -
Online video plays poorly in Safari
By kevs in forum MacReplies: 28Last Post: 22nd Sep 2008, 09:51 -
Poorly sized video on converting VCD to DVD
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2007, 02:39
