i am trying to encode my avi files to mpeg..i am using tmpgenc, wondering what are most of you out there using for bitrate? loading videocd (PAL).mcf?
whats the best quality picture when burning onto cd-r?
also besides dvd-r or cd-r..will cd-rw work on dvd standalone players??
Thanks!
Results 1 to 10 of 10
Firstly, for standard VCDs, just leave the bitrate alone. VCDs only support one bitrate for both the audio and video.
If you change the bitrate, you will be making an "XVCD", which essentially means a non-compliant VCD. Many DVD players will still play these though.
CD-R/W only works (flawlessly) on those DVD players designed to read CD-R/W media.
DVD-R and DVD-RW media work on most DVD players but not all.
Virtualdub is a linear AVI editing program.
Regards.
Michael Tam
w: Morsels of Evidence -
If you live in an NTSC country, use the NTSC template (i.e., North America, Japan).
If you live in a PAL country (i.e., everywhere else), use PAL.
Regards.
Michael Tam
This is true.
Download toolame and use it as a plug-in for TMPGEnc. You can download it at http://www.doom9.net
Regards.
Michael Tam
For TMPGEnc 12h (I presume it would be similar for other versions): Options --> Environmental Settings --> External tool --> Layer 2 --> enter the path too toolame
Regards.
Michael Tam
sorry not quite sure of how toolame works... how to use it... thanks for all your help!
whats authoring?
By templedog in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2008, 00:28 -
Whats in the pipeline?
By 2Tents in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 7th Jul 2008, 11:39 -
Whats the best way to get just the audio from a mini-dv?
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 25th Dec 2007, 19:06 -
Whats Wrong With This Forum?
By gealto2 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Jun 2007, 18:11 -
LCD TV's the whats what in buying
By CheifWigham in forum DVB / IPTVReplies: 0Last Post: 5th May 2007, 02:17
