Hi!
Has anyone been able to play miniDVD on Sansui DV-X2100. The compatibility list says that it should be possible. The player just says "Incorrect disk format". XSVCD and other things work OK. I can play the miniDVD CD with PowerDVD on my computer directly and the original ISO file also through DVD mount so I presume it should be in correct format. Is there some special trick that should be applied like the order or naming of directories or files in the disk, extra files saved etc. to get it working.
thanx for your help![]()
Results 1 to 1 of 1
deadrats' review of the i3 2100
By deadrats in forum ComputerReplies: 11Last Post: 26th Oct 2011, 21:16 -
sansui vrdvd4100A
By carolmarz in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Feb 2011, 17:53 -
Make LG DVX-286 (/ DVX-276) region-free
By joniakaidiot in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Mar 2010, 08:33 -
DVX or XL-2?
By newsphotog in forum Newbie / General discussionsReplies: 0Last Post: 16th Mar 2008, 16:48 -
Xoro HSD 2100
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd May 2007, 08:56
