How do I RIP a DVD so I can get with the text?
You want subtitles?
When you rip your DVD, make sure you rip in "File Mode" with SmartRipper or use DVD Decrypter.
Make sure that the relevant IFO files are copied over if this isn't already done.
Now, load up the relevant IFO with FlaskMPEG and you will get a choice of the video, audio and subtitle stream.
You can do subtitles with the DVD2AVI method too, but this is more complex.
For some very good guides, go to doom9's site: http://www.doom9.net
Regards.
Michael Tam
w: Morsels of Evidence
Can Projectx rip text subtitles from TS without demuxing the other streams?
By Talayero in forum SubtitleReplies: 2Last Post: 31st May 2011, 14:29 -
How to get text from a BluRay Rip
By iamkatpeeler in forum Newbie / General discussionsReplies: 20Last Post: 25th Feb 2011, 08:12 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
