Hi there,
I posted before but I'm still having some troubles so I try to ask you a precise question. Hope you can answer
I have an ATI ALL IN WONDER 8500DV (with latest driver updates) and need to convert some VHS to DivX. What's the best way to capture ? I heard of AVI, but I need to capture a 2 hours video, and I've got only 35 GB free on my HD. I've got MMC 7.7 to capture. Thanks in advance !
Results 1 to 12 of 12
Emanuele
webmaster - http://www.paolacardullo.net -
ATI captures directly to mpeg2; this will save you some hard drive space. Crack open the ATI manual (or download one from their website), and follow their instructions.
I tried to capture directly to MPEG-2, but I've got always some troubles. Even with DVD preset option, even if I make a 720x576 capture with max bitrate (15.00 Mbps) and 100 motion detection, capture isn't smooth as the source is. Any tip for this ? Thanks in advance.
Emanuele
Capture it in portions if you are running out of space. Capture with a losless Codec such as Huffy or PicVideo then resize and convert that to the MPG or DivX.
Then delete the AVI and start with the next portion. Then combine the DivX video later. I've never done DivX before, can you combine them like you can with MPG's? Anyone?
Lannie -
Perhaps I'll make some good results with Huffy ! I'll try and then tell you back. Thanks.
Emanuele
It doesn't work well ... got audio desync. Any other way ?
Emanuele
GET MORGAN MULTIMEDIA MJPEG CODEC CAPTURE VIDEO FROM VCR AT 480 BY 240 OR 400 BY 240 DEPENDING ON YOUR PROCESSOR,YOU SHOULD HAVE ENOUGH SPACE FOR 2 HR CAP. LOAD INTO VIRTUAL DUB SYNC AUDIO IF YOU WANT TO ADD FILTERS YOU CAN AND RESIZE TO.IM NOT SURE IF YOU WANT A DIVX MOVIE OR VCD IN THE END.I USE MORGAN CODEC FOR ALL CAPTURE'S THAT I PLAN TO CONVERT.
VIRTUAL DUB WILL JOIN AVI'S OF THE SAME PARAMETERS...LOAD VIDEO SELECT APPEND THEN LOAD SECOND VIDEO...THEN SELECT DIRECT STREAM COPY AND SAVE NE FILE
Manub,
Huffy is a great way to caputure and preserve quality...however it does seem to eat up alot of CPU and IDE bandwith. An option you can try is capture at a slightly lower resolution than full D1 (720x480) perhaps maybe 6xx or 4xx X 480. This may help ease the strain and keep the audio in synch..... you can always resize when you convert it to whatever resolution you are going to be watching at, and if you find the right capture res you shouldnt notice any qaulity degradation.
goodluck -
I think the best way to capture from VHS source is >>>
AVI using Huffy codec
352x576 (PAL) and then Encode the AVI file using TMPGEnc .... and by this way you'll get something I call (DVCD) or Neer DVD Quality . 8) -
How can VirtualDub correct audio/video synch problems ?
Originally Posted by DRfrankenpimp -
Most DVD's can't handle that high a bitrate anyhow.Originally Posted by manub
Try video bitrate at 8000.
I get good results with that.
Fozzee
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
