After reading many different forums, I think I am more confused now then I ever was. I cannot tell you how many different tools I have downloaded.
Now for my question: Just exactly what are the Bare Minimum Tools that I need? What I want to do is download a movie from Kazaalite and burn onto a DVD. I have the SonyDRU-5ooa Burner.
Would TMPGenc, Ulead Movie Factory and Nero be enough for what I want to do? Do I need all three?
Marilyn
You only need those 2: TMPGEnc (for encoding) and Ulead Movie Factory (for authoring and burning to DVD)
the steps are pretty simple: Use TMPGEnc's Project Wizard, choose DVD, then follow the wizard, then after several hours encoding, you will have the .mpg files. Import those mpg files in Ulead Movie Favtory then burn to DVD. -
Thank you Dodzz for getting back so quickly!
Finally I have an answer to a question I should have asked a long time ago. Wish me luck, I have been trying to do this for so long that my trial time with Tmpgenc has expired. I refuse to give up!
Thanks again,
Marilyn -
I would sugest one more (don't remember name but it should be here in guides) for checking bad frames and errors before encoding. It should save some trouble with out-of-sync issues.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Ah donpedro is right especially you're downloading movies off the kazaa thing. But I don't know the name of the program either, check out the guides on the left of this page..
Tools Needed Clean up iPhone Concert Video's Audio
By xr280xr in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2011, 18:55 -
BD rebuilder and the tools it needs
By Moontrash in forum Blu-ray RippingReplies: 4Last Post: 23rd Dec 2010, 15:56 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 13:27 -
tools needed to make a streaming website
By mr-scarface in forum Video Streaming DownloadingReplies: 5Last Post: 29th May 2009, 19:49 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
Marilyn
