Captured a lot of TV shows [all Friends eps, x files, mutants etc] from capture card [2000-2002].. what is the best settings [in terms of saving file sizes to put 10 eps or more into a DVD] what template do I use in Tempgnc.. the MPEGII and just change the aspect ratio.. as I tried to do it to 640 x 480.. it looks might strange.. as the aspect ratio of most the tv shows I captured were ranging from 352 x 240 to 640 x 480. I am not sure if I will end up watching them again... ideas would be appreciated. As it is a hobby... as I am now going to DirectTV and Tivo recording.. more easier and 100x higher quality than cable.. but hate to just delete it as it took me a lot of time then ^_^
maybe just burn them as data on dvd and watch them (if you ever are) on your pc instead .. at least you would preserve the quality you have now.. with out mucking about ..
this is all I do, go from tv capture to DVD. With tmpgenc I load the capped file as the source file and set the pixels to 720x480. Then I set the motion quality to Highest. 2-pass VBR with the highest possible average bitrate (depending on the length of the clip and the amount of high-motion scenes) is what I use, usually 1500 - 3000 - 8000.
Go here and wait a couple months. Much simpler solution for what you want to do...
http://www.smr-home-theatre.org/ces2003/sources/page_02.shtml -
10 eps per disk is asking for an awful lot (when using Mpeg2.) That's roughly 3.5hours of video. The bitrate that you would have to use would be under 4000kbps to you may actually start to loose quality. The resolutions that you are trying to use are not DVD standard resolutions (that might be why they look wierd.) The two DVD NTSC video (Mpeg2) resolutions are 720x480 and 352x480.Originally Posted by tokyootaku
What you may want to do is convert them to the VCD format Mpeg1 @ 352x240 which is also a valid dvd format. You would be able to fit at least 10 eps per disk as that the bitrate is much lower (and you could even use the vcd template in Tmpeg.) The picture is not as good but I think it would be at least VHS quality.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert X to DVD - preview videos show not correct video
By mirage0101 in forum Authoring (DVD)Replies: 3Last Post: 6th Sep 2010, 03:05 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 22:01 -
Convert a lot of DV in to MP4 at onece
By Heinh in forum Video ConversionReplies: 0Last Post: 5th Jan 2009, 18:04 -
Possible To Convert Pinnacle DC50 Captured Video?
By leebo in forum Video ConversionReplies: 13Last Post: 16th Nov 2007, 04:45
