coudl someone please help me , i have a pioneer dvd player and an xbox
i tried copying my dvds on cassettes but everytime as soon as i press record the movie starts to dim , then come off for a while then on bright then the same thing over and over. can anyone help me with that please. i would be vey grateful
It's called Macrovision proection. Search the DVD Players list over there on the left, identify your player and see if there is a hack for your player that will disable the Macrovision.
What you are seeing is macrovision copy protection. Some players have programming hacks that can defeat it, so do your research.
Hello. -
hi my dvd player is a pioneer dv343 i tried the hack to turn off the macrovision but it aint work pleae help me . thanks alot
if you can't remove macrovision from your player, there are only two solutions that come in my mind:
- if you have a dvd-rom and a video card with tv out, rip the movie removing macrovision then play the vobs from your pc
- buy another player .....
ah, you can buy one of those boxes that do the job, but i don't know if they work well. -
Originally Posted by taariqmajid
<Please don't post same question more than once - you posted it 4 times> -
The "Boxes" that is referred to in one of the posts DO work, i have one myself, i used it for copying from VHS to VHS cause commercial VHS-Tapes also use macrovision. You simply go out of your DVDplayer with a SCART Cable -> into the "Box" -> from the "Box" to the VCR, and start recording, thats all. That little thingy only costs a few bucks.
VHS to DVD Recording - 4:3 VHS Becomes Widescreen on DVD
By Ocracoke Pelican in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2011, 14:04 -
Vhs to dvd recording
By JAYHAWK1970 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 20:21 -
VHS To DVD Recording errors
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2010, 13:31 -
recording old VHS movies to DVD on LG RC389H
By gorelle in forum Video ConversionReplies: 3Last Post: 28th Dec 2009, 02:14 -
DVD-VHS Recorder Proplem with Recording
By mactek in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Nov 2008, 16:02
