Im trying to convert this movie i have thats in XVID format into MPG format with TMPGEnc. I extracted the auto (AC3) with VirtulDub and converted it into wav with HeadAC3he.
I was going to convert it when in TMPGEnc when I saw that Inverse Telecine always becomes selected even after I unselect it and restart the program. Is this due to this movie?
I went into VirtualDub and checked the File Info this is what it gives me:
Video Stream
Frame size, fps: 640x352, 23.976fps
# of frames: 102391
Decompressor: XviD MPEG-4 Codec
Audio Stream
Sampling rate: 48000Hz
Channels: 5 (Stereo)
Sample Persision: 0 -bit
Compression: Unkown (tag 2000)
I thought Inverse Telecine allows you to undo 29.976 or 30fps from a interlaced source. So I take it that I dont need to use this option since its in 23fps already. Or am I wrong?
MikeWeb
http://mikeweb.atnet.ca -
You definitely don't want to IVTC if it's already 24 fps. Just don't restart TMPGEnc. You seem to somehow have got IVTC set as your default (not sure how to deal with that without playing with TMPGEnc for a while), but just uncheck it and encode without restarting.
(How to) Inverse Telecine
By Cherbette in forum RestorationReplies: 16Last Post: 17th Nov 2011, 14:24 -
Inverse Telecine Anime (Death Note)
By Corpsecreate in forum Video ConversionReplies: 16Last Post: 7th Oct 2011, 03:55 -
Frasier DVD to iPod Inverse Telecine Help
By jmsajdak in forum DVD RippingReplies: 1Last Post: 4th Sep 2008, 10:16 -
PAL Inverse Telecine?
By Anakin in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 08:34 -
Inverse Telecine, IVTC
By kitty in forum GlossaryReplies: 1Last Post: 10th Jan 2008, 22:40
