My standalone DVD player has difficult playing SVCDs because of audio sync problems. I've seen that using the "VCD Header trick" these problems disappear. To apply the trick I use TMPGenc to demux the SVCD mpeg file and then mux it again as VCD. Then I use Nero to burn the VCD.
The problem is that the demux/mux process result on an important file size increase, and most of times the file that fit on a CD as an SVCD, won't fit on a CD as a VCD using the VCD Header trick...
What should I do to keep a similar file size so I can burn my SVCDs as VCDs without having problems because of converted file no fitting into a CD??
Thanks!
Make sure when re-multiplexing with the Header Trick that you select MPEG-1 Video CD (Non-Standard) instead of MPEG-1 Video CD in TMPGEnc. :P
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 22:07
