I used CDRDAO on one computer and it worked fine. I then used it on another and received the following message. Could someone tell me what they think? They are 2 different kinds of burners - could a burner that is not in the list cause this error? or do I need to install the Force program I have read about? Thanks!
Here is the error message that was displayed:
WARNING:
Environment variable 'HOME' not defined - cannot read .cdrdao.
ERROR: Expecting only one toc-file.
Cdrdao version 1.1.7 - (C) Andreas Mueller <andreas@daneb.de>
SCSI interface library - (C) Joerg Schilling
Paranoia DAE library - (C) Monty
Check http://cdrdao.sourceforge.net/drives.html#dt for current driver tables.
Usage: /cygdrive/c/Program Files/CopyAnyDVD/cdrdao write [options] toc-file
options:
--device <x,y,z> - sets SCSI device of CD-writer
(default: 1,0,0)
--driver <id> - force usage of specified driver
--simulate - just perform a write simulation
--speed <writing-speed> - selects writing speed
--multi - session will not be not closed
--overburn
- allow to overburn a medium
--eject - ejects cd after writing or simulation
--swap - swap byte order of audio files
--buffers # - sets fifo buffer size (min. 10)
--reload - reload the dis
k if necessary for writing
--force - force execution of operation
-v # - sets verbose level
-n - no pause before writing
Results 1 to 1 of 1
VHS to DVD conversion - Am I expecting too much?
By Office Linbacker in forum Capturing and VCRReplies: 163Last Post: 2nd Apr 2014, 10:56 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error in mp4 file
By ruicovas in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Dec 2010, 10:47 -
Error in file
By jfreak53 in forum Video ConversionReplies: 4Last Post: 26th Jan 2010, 11:49 -
Product comes out as Zero KB file, no error.
By molokaicreeper in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2009, 22:44
