  1. Have Win-TV PVR on Win98 Gold. Using WinTV2K 3.6.19004 i was able to record MPEG2(2MBit/s) videos in acceptable quality for months now. Since a few days, most recordings have NO MORE VIDEO after about 32-34min., only sound. If they have VIDEO, then there is something like a yellow shadow of an older frame and nearly no color.
    Tried complete reinstall and more, nothing helps.
    Some suggestions ?
    Greets
    BlueAce
  2. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    Have try take the card out of system, Then plug it back in?.
  3. Yes - tried. Behavior did not change. I´ve no idea what could have happened.
    Greets
    BlueAce
  4. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    sound like it something gone south on your card.
  5. what kind of imput are you using, RCA, Cable or SVHS.
  6. Hi,
    I´m using the Video-IN by a CINCH->SVHS adapter coming from a Humax5400.
    Greets
    BlueAce
    Jul 2001
    Maryland
    something on the board may be broke or not preforming corectly.
  8. Solved - and no solution )
    All the time I was using a networkdrive (over a 10MBit/s LAN) for the capture files. Seems this stopped working sufficiently from one day to other. I changed to a local drive and - works again as used before. Next days I will check it using a 100MBit/s connection. Other reason could be the disctype: the problematic one is ATA100 (too fast ), the one working is an old slow scsi )
    Thanks to all for your tips.
    Greets
    BlueAce
