Hi guys, i can't see the m2v file i am trying to open in VFAPI? i don't undersatnd why this isn't showing up,
i know it's there because i have double checked that it was there & ofcourse Smart ripper ripps it, but i am confused, this is the first time i am trying to use this program & also go through CCE.
Can anyone please give me insight to why i cannot see this m2v file that i want to re-encode to make smaller.
i had troubles the last time with REMPEG as it made the DVDR very unstable, skipps here and there, & the guide i have says this product is better, so can anyone please help me out, i am going crazy here.
Thanks,
oh also when i open DVD2AVI it asks for what compression or uncompressed files? like the guide doesn't inform me of what to do here?
here is the guide i am follwing.
http://www.dvd2dvdr.com/Spruce_Guide.htm
I first installed DVD2AVI & VFAPI in the same folder, because it said put in same directory, it does say it can see VFAPI when i open DVD@AVI, so this is why i can't understand why i cannot see?
VFAPI doesnt look for your m2v file, it looks for your d2v file what you create when you put your m2v file through dvd2avi and save project.
thingimijig.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Can Video File Be Uploaded (file share) And Downloaded in PAL Country
By studioc in forum Video ConversionReplies: 9Last Post: 3rd Nov 2009, 14:34 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
