I have done some test encoding using TMPGenc on a 1 minute piece of footage with the only filter being deinterlace even field, noise reduction and sharpen and it takes approx 3.5hrs to encode to mpeg2 (dvd template). The system I am using is not the fastest in the world and does not meet the recommended spec for tmpgenc I know however I was wondering if I could 'tweak' tmpgenc without having to buy a new PC or upgrade it (which I cant)
PC is:
Pentium 2 233
192mb Ram
Voodoo 3000 3dfx card
Any 'useful' advice appreciated.
Zed
Hi
I use a P3 450 and a 230Mb file (Half a movie) takes around 2 hours to convert with TMPGEnc to VCD.mpg
I also have a P2 233 and thought I would use it to convert the second half of the movie, the time it takes is around 3 times the P3 so the 2 hour conversion on the P3 would take 6 hours on the P2
There is a big difference, Sorry to say you need to upgrade.
But I would recommend you upgrade to the P4 when you can, price is dropping slowly. I have been tempted to upgrade this P3, but since its obsolete along with the memory type I have held back for the P4
Stop all programs running from your task bar. Defrag your hard drive before conversion. Try to have the source and destination files on different hard drives. Use a program like Winboost 2001 to tweak all your computer settings, disable the loading of unnecessary programs (drive space,double space etc) enable DMA on your hard drive (If it supports it). Work on half a movie at a time, make sure the original DivX is free from errors (Freeze frames) remove any bad frames before using TMPGEnc.
You could cut 10 minuets off the convertion time with the above
Thanks letmeinforgodsake,
Looks like im going to have to part with some wedge to get a faster PC 8(
cheers
Zed -
noise reduction by itself literally doubles encode time. sharpen is probably an additional 30-50% extra too.
zed, when you upgrade your computer get an AMD Athlon 1.2 GHZ ..... P4 sux0rz compared to that .... i personally would NEVER buy a Pentium again!! AMD forever!!
I personally would never by an AMD. Still you get what you pay for these days.
Which CPU is better and faster overall?
By Stealth3si in forum ComputerReplies: 14Last Post: 3rd Apr 2012, 09:48 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
encode HD video 558% faster!!!
By deadrats in forum Video ConversionReplies: 4Last Post: 15th Apr 2009, 22:13 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
How to burn faster
By Finfarin in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2007, 19:19
