  1. I've posted this here from the newbie forum in the hope of getting a responce.
    Right, this has only really started in the last 2 days. But I cant seem to write properly to DVD-R on my Pioneer A05 anymore.
    I'm tryinh to write Mpeg & PVA files to DVD-R, which I have never had a problem doing in the last month, never a coaster upto now. And I'm still using the same media.
    What happens is that I'm writing the disc as data using Nero5999. I've written more than a dozon DVD's this way so the method is not a problem. But every time I've tried writing a disc in the last 2 days, I've not been able to get it to burn. I get a error message saying "unexpected exception". When asked if I want to burn again or write a new disc I can opt to write another copy. This time it writes the dvd with no problems it seems. But I use the verify data setting to see if I can solve the problem. This of cause failed the disc.
    I'm no good at translating just what the log means or which part is relevent to post here so I'll paste the log:
    Windows 98 4.90 (ME)
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
    Nero Version: 5.5.9.9 (Nero Express)
    Recorder: <PIONEER DVD-RW DVR-105> Version: 1.00 - HA 0 TA 1 - 5.5.9.9
    Adapter driver: <ESDI_506> HA 0
    Drive buffer : 2000kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <PIONEER DVD-RW DVR-105>Version: 1.00 - HA 0 TA 1 - 5.5.9.9
    PIONEER DVD-RW DVR-105 (Target 1, E: Autoinsert On, DMA On, Disconnect ?, SyncDataXfer ?
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 61865984 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 511MB (523712kB)
    Free physical memory: 31MB (32548kB)
    Memory in use : 58 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Enabled (1)
    Wizard: On
    21.1.2003
    ISO compilation
    12:08:30 #1 Text 0 File Isodoc.cpp, Line 6003
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    12:08:30 #2 Text 0 File Reader.cpp, Line 118
    Reader running
    12:08:30 #3 Text 0 File Writer.cpp, Line 134
    Writer PIONEER DVD-RW DVR-105 running
    12:08:30 #4 ISO9660GEN -11 File geniso.cpp, Line 4488
    First writeable address = 0 (0x00000000)
    12:08:30 #5 Text 0 File Burncd.cpp, Line 3542
    Turn on Disc-At-Once, using DVD media
    12:08:30 #6 Text 0 File ThreadedTransferInterface.cpp, Line 663
    Setup items (original item values)
    0: TRM_DATA_MODE1 (CTransferItem)
    2 indices, index0 (150) not provided
    original CD pos #0 + 1879071 (1879071) = #1879071/417:34.21
    relocatable, CD pos for caching/writing not required/required, no patch infos
    12:08:50 #7 Text 0 File DlgWaitCD.cpp, Line 199
    Last possible write address on media: 2298495 (510:48.45)
    Last address to be written: 1879070 (417:36.20)
    12:08:50 #8 Text 0 File DlgWaitCD.cpp, Line 204
    Write in overburning mode: FALSE
    12:08:50 #9 Text 0 File DlgWaitCD.cpp, Line 1403
    Recorder: PIONEER DVD-RW DVR-105;
    CDRW code: 00 00 00 00; CD manufacturer unknown
    ATIP Data: ?
    12:08:50 #10 Text 0 File ThreadedTransferInterface.cpp, Line 815
    Prepare recorder PIONEER DVD-RW DVR-105 for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0 Close CD
    Tracks 1 to 1:
    TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 -446322688
    12:08:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 663
    Setup items (after recorder preparation)
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1879071 blocks [PIONEER DVD-RW DVR-105 ]
    12:08:50 #12 Phase 24 File dlgbrnst.cpp, Line 1566
    Caching of files started
    12:08:50 #13 Phase 25 File dlgbrnst.cpp, Line 1566
    Caching of files completed
    12:08:50 #14 Phase 36 File dlgbrnst.cpp, Line 1566
    Burn process started at 1x (1,380 KB/s)
    12:08:50 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1947
    Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
    12:08:50 #16 Text 0 File Mmc.cpp, Line 16957
    Set BUFE: supported -> ON
    12:08:51 #17 Text 0 File Cdrdrv.cpp, Line 7395
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 0 h
    End Sector Number in Layer 0: 0 h
    Data in Burst Cutting Area (BCA) does not exist
    12:08:52 #18 Text 0 File Writer.cpp, Line 318
    12:08:52.940 - PIONEER DVD-RW DVR-105 : Queue again later (Intervall : 47msec)
    12:10:16 #19 Text 0 File Writer.cpp, Line 318
    12:10:16.530 - PIONEER DVD-RW DVR-105 : Queue again later (Intervall : 47msec)
    12:55:06 #20 Text 0 File ThreadedTransfer.cpp, Line 222
    all writers idle, stopping conversion
    12:57:13 #21 Phase 37 File dlgbrnst.cpp, Line 1566
    Burn process completed successfully at 1x (1,380 KB/s)
    12:57:14 #22 Phase 78 File dlgbrnst.cpp, Line 1566
    Data verification started
    12:57:32 #23 Text 0 File DlgWaitCD.cpp, Line 204
    13:01:35 #24 SCSI -1128 File Cdrdrv.cpp, Line 1211
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0276EEFC
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x11
    Sense Qual: 0x05
    CDB Data: 0x28 0x00 0x00 0x04 0xD6 0x50 0x00 0x00 0x08 0x00 0x00 0x00
    Sense Data: 0xF0 0x00 0x03 0x00 0x04 0xD6 0x50 0x0E
    0x00 0x00 0x00 0x00 0x11 0x05
    13:01:35 #25 VERIFYERR 6 File UDFCompilationImpl.cpp, Line 5705
    Read error on CD file
    Kiosk11f - January 20 16 59 18.mpg
    13:01:37 #26 SCSI -1183 File Cdrdrv.cpp, Line 1211
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x027DEF70
    Sense Key: 0x08 (KEY_BLANK_CHECK)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x28 0x00 0x00 0x0E 0x80 0x40 0x00 0x00 0x08 0x00 0x00 0x00
    Sense Data: 0xF0 0x00 0x08 0x00 0x0E 0x80 0x40 0x0E
    0x00 0x00 0x00 0x00 0x00 0x00
    13:01:37 #27 VERIFYERR 6 File UDFCompilationImpl.cpp, Line 5705
    Kiosk11f - January 20 18 59 18.mpg
    13:01:37 #28 VERIFYERR 13 File UDFCompilationImpl.cpp, Line 6220
    Status summary
    Total files=2, identical=0, different=0, inaccessible=2, skipped=0.
    13:01:37 #29 Phase 81 File dlgbrnst.cpp, Line 1566
    Data verification failed
    13:01:37 #30 Text 0 File Scsicmd.cpp, Line 395
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'IoSubSys\SCSI1HLP.VXD': Ver=4.90.3000, size=19278 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\NEROCD95.VXD': Ver=4.5.0.14, size=39882 bytes, created 29/08/2001 23:09:58
    File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (089), size=197984 bytes, created 10/04/2000 07:10:56
    File 'IoSubsys\CDRALVSD.VXD': Ver=1.00 (1030), size=20047 bytes, created 10/04/2000 07:10:56
    File 'IoSubsys\ACBHLPR.VXD': Ver=1.01, size=40508 bytes, created 10/04/2000 07:10:56
    File 'IoSubsys\vobIW.vxd': Ver=4, 0, 2, 4667, size=142519 bytes, created 26/09/2002 17:24:58
    File 'IoSubsys\cdrdrv.vxd': Ver=4, 0, 5, 258, size=31424 bytes, created 26/08/2002 18:13:26
    File 'IoSubsys\asapi.vxd': Ver=5, 1, 0, 2, size=14581 bytes, created 01/09/1998 12:33:10
    File 'IoSubsys\CDFS.VXD': Ver=4.90.3000, size=59141 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 08/06/2000 17:00:00
    File '..\System32\Drivers\1394bus.sys': Ver=4.90.3000.1, size=44240 bytes, created 08/06/2000 17:00:00
    File '..\System32\Drivers\Ohci1394.sys': Ver=4.90.3000.1, size=49488 bytes, created 08/06/2000 17:00:00
    File '..\System32\Drivers\Sbp2port.sys': Ver=4.90.3000.1, size=36336 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\Disktsd.vxd': Ver=4.90.3000, size=18663 bytes, created 08/06/2000 17:00:00
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 08/06/2000 17:00:00 (Adapter driver for rec)
    File 'IoSubsys\ESDI_506.PDR': Ver=4.90.3000, size=25365 bytes, created 08/06/2000 17:00:00 (Adapter driver for src)
    Registry Keys:
    The data seems ok but when trying to play the files they just dont load into any media player I have.
    I've also tried burning with both Discjuggler & InstantCD/DVDv6.5. These burn the files ok. But the results are the same, they just wont load into the media players I have.
    I still have the original files on my hdd, they play fine so I know the problems cannot be with the files.
    Now some 10 coasters later I'm getting frustrated as to the cause of the problem.
    Tubol
  2. it "feels" (lots of hand waving here) like a software/driver problem. but i think you can systematically eliminate each component until you isolate the problem.
    you could try to install your a05 into a different computer and see if you have burning problems there too. this will isolate the problem to the a05 hardware if you still cannot burn with the same drive on another computer.
    if the hardware works, you could try to reinstall all your burning software or drivers. since your configuration has worked well before, something must have changed recently, and there are only 2 possible causes:
    1. hardware failed.
    2. software changed.
    good luck and let us know what you found?
    oh, one last thing. you could buy a dvd-rw to do your test burns, it saves some money in a situation like this
  3. Right, a little futher info, but this confuses things even nore for myself. And no doubt others as well.
    Right, I recorded a sample 3 min Mpeg2 clip. Using Instant CD/DVD I made a DVD video disc. Now I'd not expected it to work, but it was something to try I suppose. But amazingly it worked!. It played in my dvd writer & both my standalone dvd players.
    So the problem surely cannot be hardware?. That leaves software, but I can make a dvd video disc but not simply write Mpeg2/Mpeg & PVA files to DVD-R & be able to read from them properly.
    Confusing or what!. I've not really got a clue, but this may have happened to others with the A05 or from having a load of different software installed.
    Tubol
    And thanks for reminding me, I have a DVD-RW here somewere.
