  1. Hi,
    I'm wondering if it is possible to copy an Svcd that I've already burned to another cd-r by just using to cd copy tool of any burn program. I have a svcd that I want to make a copy and I hate to think you would have to rencode it.
    Thx,
    Wackyd
  2. Nee, nee, kein Problem, kannst du so kopieren. Entweder per CD-Copy, per Image oder indem du die MPEG-Datei aus dem MPEG2-Verzeichnis in ein neues SVCD-Projekt importierst.
    There are only 10 types of people in the world:
    Those who understand binary
    and those who don't.
  3. Thx Man but I need english. I think I kind of understood what you wrote.
  4. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    I think that I understood the tag line.
  5. Sorry, I was just posting in another, german forum and I kind of mixed that one with VCDHelp.
    You can copy an SVCD directly without problems. Either you make a CD-Copy, an image or you import the MPEG file from the MPEG2 folder into a new SVCD project.
    Hmm, actually that looks pretty much like my german post.
  6. Try clone cd. It works good for 1:1 SVCD copies.
  7. Where do I get clone cd?
  8. check your personal messeges
