i downloaded a couple of wmv files from a same source and would like to join them. i loaded the files to ASF Tools 2.30 and pressed the join button. but an error occurred saying:
"Access to the specified device, path, or file is denied."
additional info
file properties of the video files im joining:
bitrate: 1018Kbps
audio codec used: Windows Media Audio 9 20 kbps, 22 kHz, stereo (A/V) 1-pass CBR
video codec: Windows Media Video V8.1
right now im using ASF Tools 2.3 to join them and my Windows media player is version 7.01. is there any issue with this? should i download new codecs to successfully join the files together? if so, what codec should i get? Thanks people.
Do you have the latest Microsoft Windows Media 9 codecs? They are at www.microsoft.com/windowsmedia
If you are on WindowsXP then the new MovieMaker 2 beta software (free at same web site as above) will probably open them & you can join them.
If you are not on XP you can still get the WindowsMedia tools on Microsoft's site and work with them. Also Graphedit will probably work.Panasonic DMR-ES45VS, keep those discs a burnin' -
Have a play with Windows Media Components Tools, available at MicrosoftOriginally Posted by mud
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
best programs to join wmv from command line
By ziptip in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2008, 01:02 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 22:58 -
how can i join VC-1(WMV-3)files
By sumeshkri in forum Video ConversionReplies: 3Last Post: 26th Oct 2008, 00:21 -
Is there a way to join or merge WMV files?
By srauch in forum EditingReplies: 4Last Post: 8th Sep 2007, 16:39
