jacknjt said:both the phillips +R group and the pioneer -R group started development of their respective dvd recording technologies even before the dvd spec was finished, it's just that pioneer's -R was able to get to a mature level (albeit at first with only 3.95GB) and out the door a LOT faster. and they have been making SOLID dvd-recording gear for what, 5-6 years now. their "-R for General" spec has been around at least 3 years. I think they're over the beta testing by now...it's just da old format dvd-r. they made to cause trouble.If they were made to cause trouble, they wouldn't have lasted this long.
also, don't forget the big ruckus about "Book Value" switching, and the whole "+R upgrade-capable RW drive" fiasco of last year. I think +R/W is not without it's share of equipment incompatibilities.
Mostly, I think there is a problem with ANY DVD recorder when it comes to real world interfacing with various peoples' systems. This happens not just with DVD recorders, either. Why do you think this "HELP" site is so popular?
As you probably are aware, I fall in the -R/W camp. I still think +R/W, and even RAM are good, solid alternatives for certain users and certain applications.
My $.02,
Results 31 to 33 of 33
The 5 or 6(+1 or 2) companies that support DVD+R are all on the 200 + commitee list at the DVD Forum.
5 or 6(+1 or 2) independants vs. 200 world wide members
DVD-R is ISO certified for Video, DVD+R can't achieve this cert. for video, it did for data, but not video
More companies make DVD+R
DVD+R writers 29 (DVDRHELP database not settop)
AOpen, BUSlink, Freecom, HP, Ikebana, Memorex, NEC, Philips, Plextor, Ricoh, Sony, TDK, Tritton, Verbatim, Vivastar.
15 different manufactures
DVD-R writers 27 (DVDRHELP database not settop)
Asus, Cendyne, LaCie, LG, NEC, Pacific Digital, Panasonic, Pioneer, Samsung, Sony, TDK, TEAC, Toshiba, Vivastar.
14 different manufactures
hardly a difference.
DVD-R/DVD+R writers
NEC, Sony, TDK, Vivastar
Besides the ISO certification, and DVD Forum, the 2 formats are pretty much identical.
They both burn to a round disc containing ~4.7GB which is said to be 90% compatible with your settop DVD player.
Conclusion?
Since they both do the same thing, buy the one that's cheapest. -
For the same company, media prices are fairly close. For example 25 (speed 2.4x) Meritline DVD+R are $1.79 vs $1.52 for 25 (speed 2x) Meritline DVD-R. The price difference can probably be explained by the difference in speed 2.4x vs 2x. So you should go with the more compatible format: +R. Or better yet, don't choose, get the Sony drive.
http://www.meritline.com/merdvmeddvdp.html
http://www.meritline.com/mer47dvmed2x1.html
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
