Im a long time TMPG user and was wanting to try something new so I thought I'd give CCE a try, I followed the guide here: http:// www.doom9.org/mpg/cce.htm . Seems to work ok except the speed is slow(0.49). I did some messing around and if I dont load the 'fake' avi into VD and just load it into CCE w/o frameserving thru VD the speeds come up to 2.0+. Am I doing something wrong?
Is there a guide out there for a n00b CCE user that gives good speeds and quality???
Thanx
what filters are you using? those will slow down your encoding process, and that could account for the difference in speed...but I'm not sure if it would be that great. you might want to use avisynth to do your frameserving--it can do whatever VDub can, but it's faster.Originally Posted by NeWcS
try this guide:
http://www.vcdhelp.com/avitovcdfoolproofusingcce/
and remember--your quality will depend on the source.what are you askin' me for...
I'm an idiot! -
The only filter im using is the resize filter.
My source is a dvd(.vob's)
If that's the only filter, then avisynth is definitely the way to go.
what are your system specs? I run a PIII 800MHz w/512MB SDRAM, and I get about 0.5 running CCE2.5 w/avisynth and only resize filters.what are you askin' me for...
I'm an idiot! -
Duron 1.2ghz
512mb pc133
60gig WD 7200
Readon 9000 pro
etc. etc. etc.
Avisynth seems confussing, the tut on this site got me lost. Any other guide out there?
Thanx for the help thus far
check out this guide:
http://www.vcdhelp.com/forum/viewtopic.php?t=87270what are you askin' me for...
I'm an idiot!
Fit2Disc Guides
By montgal in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2009, 13:18 -
Virtualdub Guides?
By ATLien in forum Video ConversionReplies: 6Last Post: 23rd May 2009, 23:18 -
Any good guides on the Canon Xh A1s?
By Shamboola in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Apr 2009, 03:13 -
FAVC guides?
By php111 in forum User guidesReplies: 64Last Post: 25th Aug 2007, 11:53 -
question about one of the guides
By php111 in forum Off topicReplies: 1Last Post: 8th Aug 2007, 11:31
