KingJohns guide to newbie's
KingJohns Guide to Codecs V2
KingJohn Guide, My First VCD V2
KingJohns Guide Splitting Mpeg1
KingJohns Guide AVI 23.976fps to 25fps
KingJohn's Guide to bad frames V2 VBR Update
KingJohns Guide Splitting AVI
KingJohns Guide AVI Audio
KingJohns Audio Improvement Guide
KingJohns Easy, Quick DVD ripping guide *****
KingJohns Guide Merging Mpeg1
KingJohns Guide TMPGEnc Plug-in
Results 1 to 12 of 12
I really appreciate you taking the time to check out my situation, but unfortunatly it could not help a virual dub scan of my worst videos revealed
"0 bad frames,0 masked frames, 0 frames good but interleaved"
But thanks for linking me to your guides.
Can anyone shed any light as to what these commmon blocks are a result of ..i.e : compression,codec,resolution,bite rate
thanks again
King John,
Thanks for all your help with my movie files. I took the poll on vcd/dvd.
My question is. Is the site being dismantled? If not, and if the tutorials are going to be geared toward dvd, what happens to all the newbies out there? Where will their information come from. For myself, I would have never been able to do what I do with the files I download if not for VcdHelp guides
Firstly, this site being geared towards DVD authoring does not mean that existing VCD guides will disappear. It is simply a matter of future direction of this site.
Secondly, since KingJohn is not a moderator of this site (or even a member now -- he was banned) he isn't really the person you should be asking for this.
For those interested in VCD authoring, hopefully you will still find this website as relevant as ever...
Regards.Michael Tam
w: Morsels of Evidence -
ManWithaPlan said:
Yea, I don't know much about this, but I read some posts where apparently this KingJohn guy was banned for some reason or another. He said in a reply via another poster, that the moderator's of this site are cynical, (not true by any means) and that he had his attorney force this site to have his guides removed or he would pursue legal action. Someone from this site said that wasn't true, and his guides are public information, they just removed them to basically get rid of this guy all together. Hope this helps. IF you want more info, look at the "locked" thread titled Where's King John. I guess that thread should now be titled, "Where's King John AND King John's Guides."I cant access any of these links as when i click on any of them i just get a 'Missing Page'
Can you help
He can be found here
KingJohns Guides
Soon to replace above
KingJohns Guides
Come on Adam, speed it up...
oops -
Where is KingJohn? He posted right above me, I feel honored!
Hi SteveDVD
Sorry for the delay in replying, got banned
Here is the new list
[cut]
No spamming.
If you want to post a list of your guides on this forum after all, then I suggest you do so in the appropriate forum "Guides on other sites". -- vitualis
Image File Test post after failure to attach
By Snaque in forum TestReplies: 0Last Post: 15th Feb 2009, 15:29 -
My first post test
By mradio105fm in forum TestReplies: 5Last Post: 7th Feb 2009, 21:25 -
Post guide topic with external link to it
By AleksandrIgnatov in forum FeedbackReplies: 0Last Post: 18th May 2007, 04:13
