Right - you may have read about the new KiSS DVD Player DP-450 , which can play ' ISO MPEG-4 and DivX (Ver. 4 & 5) '
Searching Google for ' ISO MPEG-4 and DivX (Ver. 4 & 5) ' gives lots of referances to this player, but nothing about what this format entails; I have loads of DivX's that I was gradually converintg to SVCD to play on my cyberhome AL-528, but it seams my RAID 0 array is failing, so I'm in panic mode, burning things as avi files onto data cdr's as avi files.
For a couple of hundred pounds I could buy this player, so..
what is ISO MPEG-4 and DivX (Ver. 4 & 5)?
Basically, it's DivX v4 and 5. It should play some XviD too. the thing is, it won't play quite a good amount of movies to start with (all the old "DivX
" one) nor those using QPel or GMC, nor lots of other codecs... Just not worth the hassle imho.
If you want to play a lot of DivX, you might want to consider a HTPC instead.
Decent DVD recorder that plays AVI (DivX & XviD MPEG-4) w/HDMI out?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th Feb 2012, 19:20 -
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 18:13 -
MPEG-4 (DivX & XviD) movie discs no longer recognised by players.
By Sproggins in forum Newbie / General discussionsReplies: 11Last Post: 6th Sep 2009, 15:09 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 16:00
