I had an AIW 8500DV(currently RMA because of sound issues). When I tried capturing to vcd using their supplied programs, the picture quality was kinda bad. I already read and tried the the guides listed in VCDHelp for captureing. The ones that turned out better quality used virtual dub. Virtual Dub only captures to AVI format. I was wondering what is the best program out there to capture directly to VCD. The program DOES NOT have to be freeware. Thanks!
I am recording from my VCR using composite cables.
My system specs are:
Athlon Xp1700
Soltek SL-DRV5(KT333)
512 DDR333
ATI AIW 8500DV
SoundBlaster Live Value
IBM 80gig GXP120
Hi
This question has been asked many times if u search the forums.
Basically you WILL NEVER get good quality capturing straight to VCD format.
You need to capture high res high bitrate mpeg 1 or 2 then encode to VCD after.
This will give very good results if done properly.
I recommend PowerVCR2 and PowerDirector Pro as very good mpeg capture programs.
Fozzee -
I get good results using Intervideo WinDVR2 using the standard VCD template for capturing tv programs.
Whats the best iphone version software?
By mol3000 in forum Video ConversionReplies: 9Last Post: 7th Jan 2012, 11:21 -
whats the best software to convert flv to avi
By videodude1966 in forum Video ConversionReplies: 1Last Post: 10th Feb 2011, 04:16 -
Whats the best DVD Authoring software for me please!!
By stefanj in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2010, 14:10 -
Whats the best format for good video quality with reasonable file size
By hasanali00 in forum ffmpegX general discussionReplies: 2Last Post: 20th Feb 2010, 22:29 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 05:13
