I have ripped the "Movie Only" With DVD Dycrypter what do i have to do to burn to DVD? i have burned the VOBS i have and it wont Play on DVD player or PC?
Any help would be appreciated
MAC
You can't just rip a DVD to your HD and burn it like a CD/computer disc. Not unless you rip the entire DVD.
It sounds like you only ripped the VTS_XX files that had 'the main movie.' But not the VIDEO_TS files or the other VOB files.
Take a look at http://www.vcdhelp.com/forum/viewtopic.php?t=109346
There are basically 3 ways to go:
1) If you have a DVD-5/layer 1 disc. Use DVD Decryptor to make ISO file of disc, then burn that ISO file. Perfect backup.
2) If the disc is DVD-9/layer 2, but main movie is less than 4.7GB. Rip THE ENTIRE DVD to the HD, then use IDOEdit to strip out the main movie (and desired audio and subtitle streams). This makes new set of VIDEO_TS/VTS_XX files, which you can then burn. (scroll down to 'the enemeywithin's post on how to use IFOEdit in the above link).
3) If the disc is DVD-9/layer 2, and main movie is creater than 4.7GB you have to re-encode the movie at a lower bitrate to fit it on one disc OR spilt it onto two DVD-Rs.
Removing VOBs before burning
By drdumont in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2012, 19:29 -
Burning VOBs - error "Couldn't find any VOB unit"
By kshavo in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2009, 14:23 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
Splitting VOBs for burning to DVD ?
By paulwilko in forum Newbie / General discussionsReplies: 6Last Post: 5th Jun 2007, 04:37 -
Burning options for VOBs??
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2007, 18:32
