So heres the game - I've encoded three 50minutes film clips in tmpgenc, joined them using the same program and I would like to re-encode them to a lower bitrate, at the present 8000 I have a file 9.15Gb in size, I need to reduce it to under 4.7Gb to fit on one DVD.
When I try to open the Mpeg2 which I have just created in tmpgenc in tmpgenc,it says the file is not readable or is an unsupported format!
How do I egt the programme which ahs just created the file to recognise it and reencode to a lower bitrate?
Bill
You need to install a Mpeg 2 codec (filter) I recommend you install the Ligos LSX, it is one of 3 that will work with TMPGEnc +
Sony
Cyberlink (PowerDVD 4)
Ligos
LSX MPEG Encoder Suite 2.0
No Reencoding
By themaster1 in forum Authoring (DVD)Replies: 6Last Post: 27th Oct 2010, 10:28 -
reencoding mp4
By aeon1 in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2010, 08:35 -
Hardsub without reencoding?
By oguime in forum SubtitleReplies: 3Last Post: 9th Aug 2010, 06:42 -
Reencoding quality
By dexter30 in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2008, 16:07 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37
