Results 1 to 10 of 10
    Jul 2002
    pittsburgh
    I have an avi i want to convert to mpeg. When i load the avi in to tmpe it has no sound and gives me an error 40% thorugh the conversion. I Load the moive in to Virtual Dub
    virtualDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during this process for better compatibility. This may introduce up to 9521ms of skew from the video stream.If this is unacceptable, decompress the *entire* audio stream to and uncompressed WAV file and recompress with a constant bitrate encoder.(bitrate: 129.4 + 14.2 kbps)
    What sould i do. Can any one out there help me
    Mar 2002
    United States of America
    Go to the audio Toolbar in VirtualDub, click on Full Processing Mode, then click on compression and select "No compression" . Click on the audio Toolbar again and select conversion. Then check 44100Hz , 16 bit, High Quality, Stereo. Then click on Direct Stream Copy for both the audio and video Toolbars, then go to file and click on "Save as Avi". The new AVI will be corrected, asuuming you have all the codecs for VirtualDub
    Hope That Helps!!! :P
  3. Banned
    Jun 2001
    UK
    What sould i do. Can any one out there help me[/b]
    You cannot use Vdub normal to work with files that have VBR and Bad frames. Also did you find out why you had no sound ?, no point in doing anything untill that is sorted...
    See Vdub MP3
    http://www.vcdhelp.com/forum/userguides/135552.php
    Sound, Check your priorities
    TMPGEnc
    Option environmental settings > VFAPI plug-ins > DirectShow Multimedia File reader
    Right click on it and select higher priority, do that several times until its at the top with a value of 4, or just below any Mpeg 2 filter.
    Make sure you have the audio codec, might be AC3 missing
    http://www.vcdhelp.com/forum/userguides/135217.php
    Jan 2003
    Niagara Falls
    Originally Posted by puertorican138
    Go to the audio Toolbar in VirtualDub, click on Full Processing Mode, then click on compression and select "No compression" . Click on the audio Toolbar again and select conversion. Then check 44100Hz , 16 bit, High Quality, Stereo. Then click on Direct Stream Copy for both the audio and video Toolbars, then go to file and click on "Save as Avi". The new AVI will be corrected...
    Would I then have to convert the new AVI to WAV for use in tmpgenc or can the new AVI (no compression) be used?
  5. Banned
    Jun 2001
    UK
    [quote]
    [/quote
    If you use Direct stream copy, you cannot convert anything to anything, you need to use full processing mode for audio, and if you used it for video it would be huge
    Jan 2003
    Niagara Falls
    So, would I have to convert the new (non-VBR) AVI to WAV using full processing mode and then use it in TMPGenc, or can I use the new
    (non-VBR) AVI as the audio source in TMPGenc?
    Jan 2003
    Niagara Falls
    If I click "full processing mode" in the first step, then make my changes in compression and conversion, Well when I go back to the audio and select "direct stream copy" it cancels out "full processing mode". Is it suppose to do that?
    Mar 2002
    [quote="frink"]
    Yes, as "Direct Stream Copy" saves out another copy without any editing. Make sure when you go back to audio after performing the steps that it's on "Full Processing Mode" instead of "Direct Stream Copy".
  9. Another pretty good program IF you plan to convert you AVI to Mpeg/VCD, is Decompressor, it's very easy to use, it comes with AVI2VCD. I use it all the time because TMPGEnc cannot process compressed Audio very well, problems, Jerkiness, syncing..etc.
    Jan 2003
    Niagara Falls
    Now I'm supremely confused! If selecting "direct stream copy" cancels out "full processing mode" then why do I select it in the first place?
