run top or ps in a term. If mpeg2enc isn't running, that's your problem. See the other posts about getting this installed properly.Originally Posted by OSx
This issue is being addressed even as we speak
-K
Results 61 to 90 of 142
i just encoded a movie with great quality and in sync, but i want to the cut out the credits and the intro and qt isnt letting me do it, any suggestions?
less than jake, wooo hooo!!!!! -
the above post came from trying to make a vcd. this is what i got from trying do to a divx:
It means that the BSD package isn't installed on your system.Originally Posted by ryanremigio
The next version of forty-two checks for this, and the updated docs make this clear as well
(Who knew?)
Its on your OS X install CD. Look for a package named BSD and install that
-K -
forty-two seems like a great program, once i get it working...
i start it up, and it says mpeg2enc is missing, download?
i say yes, but it says error: curl: (23) failed writing body (23)
can you help me out here? -
Just wondering, what do the numbers at the bottom mean?Code:
************************************************ **** Your system is too SLOW to play this! **** ************************************************ Possible reasons, problems, workarounds: - Most common: broken/buggy _audio_ driver - Try -ao sdl or use ALSA 0.5 or the OSS emulation of ALSA 0.9. - Experiment with different values for -autosync, 30 is a good start. - Slow video output - Try a different -vo driver (-vo help for a list) or try -framedrop! - Slow CPU - Don't try to play a big DVD/DivX on a slow CPU! Try -hardframedrop. - Broken file - Try various combinations of -nobps -ni -forceidx -mc 0. - Slow media (NFS/SMB mounts, DVD, VCD etc) - Try -cache 8192. - Are you using -cache to play a non-interleaved AVI file? - Try -nocache. Read DOCS/video.html and DOCS/sound.html for tuning/speedup tips. If none of this helps you, read DOCS/bugreports.html. A:1916.8 V: 900.2 A-V:1016.588 ct: 89.942 21584/21584 75% 528% 49.7% 21551 0 0A:1916.9 V: 900.2 A-V:1016.647 ct: 89.946 21585/21585 75% 528% 49.7% 21552 0 0A:1917.0 V: 900.3 A-V:1016.691 ct: 89.950 21586/21586 75% 528% 49.7% 21553 0 0A:1917.0 V: 900.3 A-V:1016.719 ct: 89.954 21587/21587 75% 528% 49.7% 21554 0 0A:1917.1 V: 900.4 A-V:1016.778 ct: 89.959 21588/21588 75% 528% 49.7% 21555 0 0A:1917.3 V: 900.4 A-V:1016.920 ct: 89.963 21589/21589 75% 528% 49.7% 21556 0 0A:1917.4 V: 900.4 A-V:1016.958 ct: 89.967 21590/21590 75% 528% 49.7% 21557 0 0A:1917.5 V: 900.5 A-V:1016.982 ct: 89.971 21591/21591 75% 528% 49.7% 21558 0 0A:1917.9 V: 900.5 A-V:1017.377 ct: 89.975 21592/21592 75% 528% 49.7% 21559 0 0
I've got a 5.95 GB avi file on my HD right now. 400 MB mpv right now. I only have about 3.8 GB left of hard drive space. Stupid me. I should have started this on the other partition. But maybe I'll have just enough space for this to work. At this stage of the game I can delete the test .mpgs right, to free up some space?
This program seems to wreak havoc with my clock too. But that's easily corrected.
EDIT:
OK I've deleted both test .mpgs and some other files. mpv file now 440 MB, and I've got 4 GB left.
Now to go to bed and let this run overnight... and then some...
Seems like a great program by the way. Great work! -
check the other messages for a quick fix. A new version of forty-two is being worked on that fixes this, and other issuesOriginally Posted by sickdimension
-K -
sorry didn't realize a question was already answered-- ignore this post
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
Great Job on this program, this is the first In Sync SVCD I have made, and On my first try no less
Any way one quick question....
How many pass VBR does the program use? I see that the sample is set to one pass is it the same for the full movie?
Ok I lied two questions is there a way to set how many passes the encoder uses now, or in the future
maybe like a checkbox for 2,3 or 4 pass.
Again thanks for the in sync SVCD.Kevin
Webmaster of Gatesisthedevil.com -
That's the vision we had. You have no idea how happy it makes me to see folks say things like thisOriginally Posted by gatesisthedevil
forty-two currently does 1-pass encoding, with high bitrates. It aims for ease and quality, moreso that size.Any way one quick question....
Mpeg2 encoding will always be 1 pass, as this is all the encoder supports at this time.
Mpeg1 could be multi-pass, as well as Divx.
As low as it is, don't you think you'd get into diminishing returns?
40 hours for a 10% savings and +5%-10% quality? I dunno...
-K -
Kai,
Great job on 42. I know I did something wrong during the install. The terminal window closed before I could get the output, but basically it tried to play back the test file and couldn't find it. I used the line you posted to d/l mpeg2enc directly to the folder with the terminal. I also got some stuff about trying to find the font folder. I've scoured this entire thread, and for each poster that had similar issues, there was a fix, I just need mine. Thanks. I will definitely be donating. I had given up on making svcds. I was planning on buying a set-top DivX player. Thanks again.
Jeremy (another jeremy) -
Originally Posted by KaiCherry
Hmm...I have the BSD package installed and I get the same error every time. Here's the terminal output :
STATUS: Phase 1 Analysis
STATUS: This content is safe to encode at NTSC Film Rate
STATUS: Phase 2 Analysis
STATUS: Checking Audio Format...
STATUS: Using MP3 VBR...
STATUS: Encoding 1-Pass Test Clip at your Requested Quality
STATUS: Copying test clip to /Users/philip/testmDVD
cp: mDVD: No such file or directory
STATUS: Playing test clip...See README
MPlayer CVS-030118-18:03-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
Reading config file /Users/philip/.mplayer/config
Reading /Users/philip/.mplayer/codecs.conf: can't open '/Users/philip/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: 44 audio & 112 video codecs
font: can't open file: /Users/philip/.mplayer/font/font.desc
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (212 chars)
Using usleep() timing
Can't open input config file /Users/philip/.mplayer/input.conf : No such file or directory
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
Playing mDVD
File not found: 'mDVD'
Exiting... (End of file)
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
1323
STATUS: Ok...Encoding DVD to DivX...ZZZZzz
syntax error: Expected end of line, etc. but found ?end tell?. (-2741)
Disk Utility Tool ?2002, Apple Computer, Inc.
Usage: diskutil [mount(Disk)|unmount(Disk)|eject]
[Mount Point|Disk Identifier|Device Node]
Mount, unmount or eject disks or volumes. Root access is not required.
Example: diskutil unmount /Volumes/SomeDisk
Something funny is going on...
philip -
Finally got it to work! YES! I'm working on a vcd right now, almost done. Question...I did not check the first selection, the bitrate button? What is going to happen? So far I have a mpv that is 809mb and an mp2 that is currently 74mb. How is this going to fit on a cd? Or will it automatically create 2 files for 2 cds.
I have been ripping from a dvd full of tv show episodes. The first episode ripped perfectly (which is awesome considering the trouble I have had with this in other apps). However, when I try to rip the 2nd episode I check rip title stream and type in 02 (which is the track number) . forty two then proceeds to rip episode 1. What am i doing wrong?
Bile, the Insomnia dvd I am talking about is not the american movie with Robin Williams, but a Norwegian flick of the same name (if you ripped this movie, that is very cool). The yuvscaler only hangs on this and a couple of other movies. It works perfectly on all other movies that I have tried (i have ripped around 10) so it can't be a problem with mpeg2enc. I get the same error with all criterion disks that I have tried. If anyone has managed to rip a criterion disk (especially one with subs) let me know
One of the criterion disks (sanjuro) will sort of rip in ffmpegX, but I have to do it with quicktime encode and therefore have synch problems and no subtitles (and I can't speak japanese, hehe).
- Elreeko
"I have not failed. I have simply discovered what does not work." - Thomas Edison -
I have been trying to do a dvd -> dvd downsample for super troopers for two days and have scoured the postings but i am still getting errors and a scratch folder with some files, biles.mpv that is about 8k and three others with 0k or 4k sizes.
Last nite it looked like it was working but this morning, nada. Before I was not even getting past the preview portion so I replaced all the linked files with fresh ones and made sure none of them were labelled as text files. I did the commandline retrieval of the mpeg2enc. No change. I also downloaded the latest build of 42. still nothing. I figured it might be the settings I was putting in so I stopped selecting the checkbox for using english and for ripping title stream. So last nite with nothing selected except the check for dvd i started it again for the 5th time or so and after the usual preview played, it didn't quit but actually seemed like it was starting to encode because it stopped on the ripping and encoding message and stayed like that for quite some time. Went to sleep and this mornign the following terminal messages appear. I'm at a lost.... any ideas?
STATUS: Ok...Encoding DVD to DVD...Cop a walk or something. I'll let you know if there is a problem, or when we are done...
STATUS: Ripping and encoding video...Zzzzz
STATUS: Here is your DVD...we are done with it...
Disk /dev/disk2 ejected
mkfifo: /scratch/stream.yuv: File exists
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
AltiVec found
Reading config file /Users/arla/.mplayer/config
Reading /Users/arla/.mplayer/codecs.conf: can't open '/Users/arla/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'null' '-v' '-osdlevel' '0' '-font' '/Library/Application Support/forty-two/font/font.desc' '-fps' '23.976' '/scratch/movie.mpg.avi'
Font /Library/Application Support/forty-two/font/font.desc loaded successfully! (233 chars)
Using Unoptimized OnScreenDisplay
get_path('input.conf') -> '/Users/arla/.mplayer/input.conf'
Can't open input config file /Users/arla/.mplayer/input.conf : No such file or directory
get_path('movie.mpg.avi.conf') -> '/Users/arla/.mplayer/movie.mpg.avi.conf'
Playing /scratch/movie.mpg.avi
[vobsub] subtitle (vobsubid): 0 language xx
No matching VOBSUB languge found!
Not an URL!
File size is 4547517616 bytes
AVI file format detected.
list_end=0x13A
======= AVI Header =======
us/frame: 41708 (fps=23.976)
max bytes/sec: 0
padding: 0
MainAVIHeader.dwFlags: (2320) HAS_INDEX IS_INTERLEAVED TRUST_CKTYPE
frames total: 144045 initial: 0
streams: 2
Suggested BufferSize: 0
Size: 720 x 480
list_end=0xD4
==> Found video stream: 0
======= STREAM Header =======
Type: sdiv FCC: (0)
Flags: 0
Priority: 0 Language: 0
InitialFrames: 0
Rate: 239760/10000 = 23.976
Start: 0 Len: 144045
Suggested BufferSize: 165669
Quality 0
Sample size: 0
found 'bih', 40 bytes of 40
======= VIDEO Format ======
biSize 40
biWidth 720
biHeight 480
biPlanes 1
biBitCount 24
biCompression 268435458=''
biSizeImage 1036800
list_end=0x13A
==> Found audio stream: 1
Type: sdua FCC: (0)
Flags: 0
InitialFrames: 0
Rate: 56000/1 = 56000.000
Start: 0 Len: 336442624
Suggested BufferSize: 28000
Quality 0
Sample size: 1
found 'wf', 18 bytes of 18
======= WAVE Format =======
Format Tag: 8192 (0x2000)
Channels: 2
Samplerate: 48000
avg byte/sec: 56000
Block align: 1
bits/sample: 16
cbSize: 0
list_end=0x16E
hdr=Software size=31
Software : MEncoder CVS-030118-18:03-3.1
Broken chunk? chunksize=1674 (id=KNUJ)
list_end=0x0
Found movie at 0x80C - 0xFFFFFFFF
stream_seek: WARNING! Can't seek to 0x150EED83C !
Auto-selected AVI audio ID = 1
Auto-selected AVI video ID = 0
AVI: Searching for audio stream (id:1)
AVI video size=4209920572 (144045) audio size=336442624
VIDEO: [] 720x480 24bpp 23.98 fps 5605.9 kbps (684.3 kbyte/s)
Searching for sequence header... OK!
VIDEO: MPEG2 720x480 (aspect 3) 29.97 fps 12250.0 kbps (1531.2 kbyte/s)
[V] filefmt:3 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Clip info:
Software: MEncoder CVS-030118-18:03-3.1
Opening audio decoder: [liba52] AC3 decoding with liba52
dec_audio: Allocating 3840 bytes for input buffer
dec_audio: Allocating 6144 + 65536 = 71680 bytes for output buffer
No accelerated IMDCT transform found
AC3: 5.1 (3f+2r+lfe) 48000 Hz 448.0 kbit/s
A52 flags before a52_frame: 0x2A
A52 flags after a52_frame: 0xA
No accelerated resampler found
AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 56000->192000 (448.0 kbit)
Selected audio codec: [a52] afm:liba52 (AC3-liba52)
vo_yuv4mpeg: Using (default) progressive frame mode
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vop scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
The selected video_out device is incompatible with this codec.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder v2.0
libmpeg2: No accelerated IDCT transform found
libmpeg2: No accelerated motion compensation found
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO Config (720x480->854x480,flags=0,'MPlayer',0x32315659)
VO: [yuv4mpeg] 720x480 => 854x480 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools (to "stream.yuv")
VO: Author: Robert Kesterson <robertk@robertk.com>
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
AO: [null] 48000Hz 2ch Signed 16-bit (Big-Endian)
AO: Description: Null audio output
AO: Author: Tobias Diedrich
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
[libaf] Adding filter dummy
[dummy] Was reinitialized, rate=48000Hz, nch = 2, format = 0x00000000 and bps = 2
FPS forced to be 23.976 (ftime: 0.042)
Starting playback...
*** [vo] Allocating mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
XXX initial v_pts=0.000 a_pos=28000 (0.500) 1 0% 0% 0.0% 0 0 0%
12:12AM up 2:11, 3 users, load averages: 0.62, 0.68, 0.85
STATUS: Fixing up AC3...
Input #0, avi, from '/scratch/movie.mpg.avi':
Stream #0.0: Video: , 720x480, 23.98 fps, 800 kb/s
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
Output #0, ac3, to '/scratch/movie.mpg.ac3':
Stream #0.0: Audio: ac3, 48000 Hz, stereo, 448 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Warning, allocating 0 bytes
Press [q] to stop encoding
size= 0kB time=10000000000.0 bitrate= 0.0kbits/s
rm: /scratch/audiodump.wav: No such file or directory
STATUS: Multiplexing...
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/04/20 19:08:30 $)
**ERROR: [mplex] Unable to read from file /scratch/biles.mpv. -
Folks running into the "no such file or directory" lines etc...
Seems to have worked for me...This is what Kai said to me, and it worked fine...
mpeg2enc seems to not be installed properly.
if there is an mpeg2enc in your app support forty-two folder, erase it.
open a term, paste this in, all one line:
cd /Library/Application\ Support/forty-two && curl http://mjpeg.sourceforge.net/MacOS/mpeg2enc -O
then re-run forty-two
Hi...Originally Posted by kaneda006
Please be as specific as possible as you can about any issues you are having, and please read the readme enclosed. It sounds like you didn't copy the forty-two folder from the disk image to the proper location, but its hard to be sure from what you've typed here.
-K -
my first ever vcd created flawlessly on my mac!!! wow...that was awesome. checked a few buttons, walked away for about 5 hours then BAM, vcd creation. such a fine piece of software. great job guys! now i want to try to create a dvd....
Kai,
I could father your children for the support you are giving us, keep up the work. : ) Here's my terminal output.
Volume /Volumes/DVD_VIDEO unmounted
STATUS: Encoding at NTSC Video Frame Rate to insure proper Sync
STATUS: Copying test clip to /Users/jeremybo/testlawrence.avi
cp: lawrence.avi: No such file or directory
MPlayer CVS-030122-17:15-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec not found
Reading config file /Users/jeremybo/.mplayer/config
Reading /Users/jeremybo/.mplayer/codecs.conf: can't open '/Users/jeremybo/.mplayer/codecs.conf': No such file or directory
font: can't open file: /Users/jeremybo/.mplayer/font/font.desc
font: can't open file: /usr/local/share/mplayer/font/font.desc
Can't open input config file /Users/jeremybo/.mplayer/input.conf : No such file or directory
Playing lawrence.avi
File not found: 'lawrence.avi'
execution error: Terminal got an error: Reply has not yet arrived. (-1718)
1048
Disk /dev/disk1 ejected
[kaneda:~] jeremybo%
I'm trying to rip Lawrence of Arabia. Any help would be useful. I did the terminal mpeg2enc install. I went into the properties and deleted the .txt extension. I can't wait for this to come together...
P.S. the whole father of your children thing is contingent on my first rip...haha
Congratulations on a fantastic application. First try on converting a german DVD (The Mummy) to english VCD worked flawlessly. Very impressive.
One observation and one request:
My PAL DVD produced a NTSC VCD. This is actually what I wanted but I assumed the default case would be PAL to PAL or NTSC to NTSC, as I imagine the normal user would want this.
Is it possible to add the possibility of Finnish Subtitles and Finnish Language? Please!......
Thanks a lot for all the hard work leveling the playing field for us Mac users. -
i got the following again, after my second attemp to rip Spirited Away, the region 2 NTSC Japanese version. it can't find the ac3 file, which sucks casue the video turned out so great and with the subs. any thoughts on hw to fix this? i've made 1 vcd so far and it tunred out great. and i tried this dvd twice and no luck. i'm also trying another reg. 2 ntsc japanese dvd Kiki's Delivery Service (something like that) and when i choose english subtitles, japanese also pop up, so i tried selectedting the japanese option like maybe they were switched and i still got japanese. didn't try to french option yet, but there are englich subs on the disc casue they work on my player. and for the spirited away dvd the english subs worked great.
any thoughts on how to fix this can't find ac3 file would be greatly appreciated. or also how to just keep the video mpeg file i have and rip the audio to match?? the video was 23.978, so not sure hot to do this?
thanks
pants
179134/179134 45% 385% 5.4% 96033 0 A:7471.6 V:7471.4 A-V: 0.196 ct:746.469 179135/179135 45% 385% 5.4% 96033 0 A:7471.6 V:7471.4 A-V: 0.154 ct:746.473 179136/179136 45% 385% 5.4% 96033 0 A:7471.6 V:7471.5 A-V: 0.112 ct:746.477 179137/179137 45% 385% 5.4% 96033 0 A:7471.6 V:7471.5 A-V: 0.071 ct:746.482 179138/179138 45% 385% 5.4% 96033 0 A:7471.6 V:7471.6 A-V: 0.029 ct:746.484 179139/179139 45% 385% 5.4% 96033 0 ds_fill_buffer: EOF reached (stream: video)
A:7471.6 V:7471.6 A-V: 0.029 ct:746.487 179139/179139 45% 385% 5.4% 96033 0 EOF code: 1
Uninit audio filters...
[libaf] Removing filter dummy
uninit audio: liba52
uninit video: libmpeg2
DEMUXER: freeing demuxer at 0x2cb5a30
10:52AM up 10:11, 3 users, load averages: 2.51, 2.27, 2.18
Input #0, avi, from '/Users/superpants/Spirit_Temp/Spirited.mpg.avi':
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 384 kb/s
Output #0, ac3, to '/Users/superpants/Spirit_Temp/Spirited.mpg.ac3':
Stream #0.0: Audio: ac3, 48000 Hz, stereo, 384 kb/s
Stream mapping:
Stream #0.1 -> #0.0
rm: /Users/superpants/Spirit_Temp/audiodump.wav: No such file or directory
[patrick-tulipanos-Computer:~] superpants% eam.
**ERROR: [mplex] Unable to read from file /Users/superpants/Spirit_Temp/Spirited.mpg.ac3.pants on, pants off, pants the floor. -
just out of curiosity, what is the timeframe on doing a dvd--->dvd? i started Blue Crush last night around 2am and it is still going....verified by running top and seeing the mpeg2enc is still running....is it? or is it hanging? it still shows cpu ranges from 70%.....i have a g4 800 w/ 512 RAM....nothing else running on the box.....
thanks -
i did a dvd to dvd and it went from about 1:30 am to 11 am, on a dp 800 w/ 1 gig ram.
I'd like to retract my statement about things being fixed...
I still get this stuff...Code:AltiVec found Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory Reading config file /Users/omega/.mplayer/config Reading /Users/omega/.mplayer/codecs.conf: can't open '/Users/omega/.mplayer/codecs.conf': No such file or directory Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory Using built-in default codecs.conf CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '-font' '/Library/Application Support/forty-two/font/font.desc' '-fps' '23.976' '/Users/omega/Desktop/DVDs/42ROMEO_JULIET/Romeo_Juliet.mpg.avi' Font /Library/Application Support/forty-two/font/font.desc loaded successfully! (233 chars) Using Unoptimized OnScreenDisplay Using usleep() timing get_path('input.conf') -> '/Users/omega/.mplayer/input.conf' Can't open input config file /Users/omega/.mplayer/input.conf : No such file or directory Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory Falling back on default (hardcoded) input config get_path('Romeo_Juliet.mpg.avi.conf') -> '/Users/omega/.mplayer/Romeo_Juliet.mpg.avi.conf' Playing /Users/omega/Desktop/DVDs/42ROMEO_JULIET/Romeo_Juliet.mpg.avi [vobsub] subtitle (vobsubid): 0 language xx [vobsub] subtitle (vobsubid): 0 language xx No matching VOBSUB languge found!
Getting closer to getting results. Finally have a few of the files in the correct folder, and I dont get the missing mpegenc any longer. But I do get the following: (This DVD wont work under the super video option), only divx.
I am not getting any results. What do I need to do??, at least it goes to the terminal now..
Last login: Thu Jan 23 15:30:11 on ttyp2
/tmp/.wd
Welcome to Darwin!
[My-Name-Computer:~] myname% /tmp/.wd
Welcome to dvdvx!
(C) 2003 Kai Cherry. All Rights Reserved.
forty-two and its associated engines is Donationware. *Please* consider a donation...as little as a few dollars
means a lot to an out of work coder with bills, such as myself. Thanks!
Begging ends...
Disk Utility Tool 2002, Apple Computer, Inc.
STATUS: Copying test clip to /Users/myname/testnDVD
cp: nDVD: No such file or directory
AltiVec found
Reading config file /Users/myname/.mplayer/config
Reading /Users/myname/.mplayer/codecs.conf: can't open '/Users/myname/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: this codecs.conf is too old, incompatible with this mplayer release! at line 6
font: can't open file: /Users/myname/.mplayer/font/font.desc
Can't open input config file /Users/myname/.mplayer/input.conf : No such file or directory
Playing nDVD
File not found: 'nDVD'
679
syntax error: Expected end of line, etc. but found “end tell”. (-2741)
THANKS, for any help -
When encoding an SVCD what is the final result? two MPG files? a handful of IMG files to burn?
Let me know,
Thanks... -
Presently, forty-two is NTSC only. Support is sloooowly tricking in however, and if we get enough requests, we will most likely produce a PAL version.Originally Posted by jeffbay
This is a feature of the version we are currently working on.Is it possible to add the possibility of Finnish Subtitles and Finnish Language? Please!......
-K
How do I download this?
By Smack2k in forum Video Streaming DownloadingReplies: 4Last Post: 2nd Mar 2011, 12:06 -
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 11:13 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 02:29
