During the burning process of DVD Movie Factory 1, I get the following error:
"Some chapter entry frame numbers exceed the total frames"
What does DMF1 mean by that? Do I need to put less chapters on my movie? I only have six on a custom menu background.
Please advise. Thanks.
Sounds like you found a bug in the software. There are several in version 1 and there were updates available at ulead.com. (They may not be there now sense version 2 is out.)
There are 29.97 frames per second of video and the software is saying that one or more of your chapter points has a higher frame number then the total number of frames in your video. Not a good thing.
You should be able to have 10, 20, 30 or more chapter points.
I'd try creating the VIDEO_TS folder without any menu on the hard drive, and see if it plays all the way through with PowerDVD or WinDVD on your computer. -
I found out the problem was with a file that I edited using NanoMPEG Editor. When I use the original file without any trimming, DMF1 handled it fine.
Movie Factory 6+ with HD-DVD Plugin
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2010, 12:20 -
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
