    Jan 2003
    Texas
    i have some videos in quick time, but i would like to capture a frame of that video and print it out as a picture, any help on how i can do this. thank you for your help
  2. Member twodogs's Avatar
    Dec 2002
    Australia
    Many methods will work:
    Open MOV in TMPGEnc (dont forget QTReader plugin, also you can select source range for fewer frames under Settings button, Advanced, Source Range)
    Then: File -> Output to File -> Image Sequence (JPEG, BMP etc)
    or,
    convert to MPEG in TMPGEnc, then load MPEG into VirtualDub, then File -> Save Image Sequence
    or,
    "speed's just a question of money. How fast can you go?" - Mad Max, 1979
    Jan 2003
    Texas
    or? or what, thanx 4 your help
  4. Member twodogs's Avatar
    Dec 2002
    Australia
    ..or many other methods using $oftware.
